Main > Software Forum
Trouble with new MAMEwah 0.97 AND Butler's new MAMEwah setup
Pages: << < (4/10) > >>
Stormy151:
--- Quote from: Minwah on May 20, 2004, 05:34:43 am ---I think you misunderstood somewhat what that option is there for  :P
It does exactly what it says, puts quotes around the romname when launching the game.  For MAME, you don't need to use this option (that's why it's disabled by default), but I think some emulators require quotes for long filenames to work.
The bracketed stuff in the games list will always be there in the Main List.  Generate a Custom List using Filters and it will not show up in that list, as long as you have 'Display Clone Info (in Custom Lists)' set to 'No' (it is set like this by default).
Ohhhhh.  I thought it was to get rid of all the extra characters in the rom name when you generate the gamelist, which are common in NES emulators.  Oops.  :(
Minwah:
--- Quote from: Stormy151 on May 20, 2004, 04:05:53 pm ---Ohhhhh.  I thought it was to get rid of all the extra characters in the rom name when you generate the gamelist, which are common in NES emulators.  Oops.  :(
No worries...as I say you can do this by generating a custom list using filters...but there's a catch: if you don't have any info to filter on, then you can't do it!  If you have a dat file with some filter-able info in it (I don't know if these are available for consoles) then you could use the DAT File List Generation Method.
Next version I will make it so that you can generate a custom list even if there is nothing to filter on, purely for this reason :)
timsatari:
Ok, my NEXT error  :o when trying to run Mamewah (after deleting old config files) is 'Run time Error 380' invalid property value' - what's this one mean? Again, I've tried uninstalling / reinstalling etc...but still weirding out on me! is the Mamewah Setup proggie affecting it now?
Dave Butler:
Are you getting the 'Run Time error 380' when you run MAMEWAH or MAMEWAH Setup?
timsatari:
I get the error when I run Mamewah...
Go to full version
