Main > Software Forum
Trouble with new MAMEwah 0.97 AND Butler's new MAMEwah setup
Pages: << < (3/10) > >>
Stormy151:
Got it. :)
How is it supposed to work?
EDIT-  OK, I turned it on- the games run fine, but I still have all the extra crap in the gamelist, like Contra (USA) (1.2) etc.  I tried refreshing the game list, but nothing changed.
timsatari:
I was having problems with installing a layout so I decided to try Mamewah setup proggie..now no matter what I do, I cannot stop getting the runtime error 13 message!! I've tried uninstalling, reinstalling, restarting...
I also got a message to insert my XP install CD as mamewah setup installed 'older' drivers... is this correct?
thanks!
tim.
Minwah:
--- Quote from: Stormy151 on May 19, 2004, 07:32:26 pm ---Got it. :)
I think you misunderstood somewhat what that option is there for  :P
It does exactly what it says, puts quotes around the romname when launching the game.  For MAME, you don't need to use this option (that's why it's disabled by default), but I think some emulators require quotes for long filenames to work.
The bracketed stuff in the games list will always be there in the Main List.  Generate a Custom List using Filters and it will not show up in that list, as long as you have 'Display Clone Info (in Custom Lists)' set to 'No' (it is set like this by default).
Minwah:
--- Quote from: timsatari on May 19, 2004, 11:15:48 pm ---I was having problems with installing a layout so I decided to try Mamewah setup proggie..now no matter what I do, I cannot stop getting the runtime error 13 message!! I've tried uninstalling, reinstalling, restarting...
Sounds like you messed up your CFG files somewhere along the way...delete your \MAMEWAH\Files folder and start again...
Not sure about the drivers thing  ???
Dave Butler:
--- Quote from: timsatari on May 19, 2004, 11:15:48 pm ---I also got a message to insert my XP install CD as mamewah setup installed 'older' drivers... is this correct?
I've checked the installer and all the DLL/OCX files are set not to install if a higher version of the file allready exists. So in theory the older version should no be installed. ???
Any idea which drivers needed to be reinstalled.
Go to full version
