Main > Software Forum
Running CHD games
Pages: << < (4/6) > >>
dema:
I was looking for the U64 emulator originally but then I read that it was the N64 version. If that's the case then why don't you just run the game from the N64 emulator instead of the U64 emulator?
walls83:
The U64Emu is not a Nintedo 64 emulator it is the Arcade version of KI and KI2 hardware emulator.
dema:
--- Quote from: walls83 on May 18, 2004, 02:14:06 am ---The U64Emu is not a Nintedo 64 emulator it is the Arcade version of KI and KI2 hardware emulator.
I wasn't aware of that. I hear that it can run KI 1 and 2 better and smoother than it does on MAME. I just thought it was because it was the console version, but I was wrong. Thanks for the heads up.
simplygriff:
So if I understand correctly...
I can put the same roms from Mame into u64's roms folder and it will work?  Do I need to unzip the roms?  Just trying to clear some things up so I can try this.  Thanks.
-G
Tiger-Heli:
--- Quote from: simplygriff on May 18, 2004, 10:05:15 am ---So if I understand correctly...
-G
Mr.Bond said the roms need to be unzipped in u64's roms folder.  I haven't used the program.
Go to full version
