Main > Software Forum
Running CHD games
Scoobie:
I read this thread, but it's a lot of code talk and besides, I'm running Mame32. How do I underclock the game processors Mame32?
Tiger-Heli:
--- Quote from: Scoobie on May 14, 2004, 01:23:32 pm ---I read this thread, but it's a lot of code talk and besides, I'm running Mame32. How do I underclock the game processors Mame32?
Options - Default Game Options - Miscellaneous Tab - Click on "Enable game cheats"
With that done, you can use the Tab menu and the arrow keys to see how much to under/over clock the processors.
Then you can edit the cheat.dat file (you might have to get one and put in your MAME32 folder), so it does the required overclock at startup.
Scoobie:
I now have a cheat.dat file in my MAME32 folder and have checked the "enable game cheats".
How do I edit the cheat.dat file in MAME32? What do I press, and where do I go?
Tiger-Heli:
--- Quote from: Scoobie on May 15, 2004, 05:09:39 pm ---I now have a cheat.dat file in my MAME32 folder and have checked the "enable game cheats".
Just open it in Wordpad, type the entries in, and save as a .txt file (keep the .dat extension, though).
MrBond:
I know this isn't exactly what you are talking about, but you may try running the u64emu emulator. It was developed specifically for KI and KI2 and both games run great on both my machines (1.6GHz and 2.6GHz). I did a quick google search and here's one download spot:
http://www.sys2064.com/u64.htm
Note, you'll need a "ki.img" or "ki2.img" file...
"roms" are same as MAME, but you will need them unzipped in the roms folder.
Also, you may want to try Howard's U64 wrapper at:
http://www.oscarcontrols.com/lazarus/wrapperdownload.html
If you don't know what a wrapper is (basically allows you to more easily play the game on a cabinet...like with the nice "esc" exit), don't worry about it, you can run the game from the emu itself.
PM me if you have any problems (if you try it in the first place!)
~Mrbond
