Author Topic: 1 Player Cab Only...Should I hack a pad or keyboard or still buy IPAC?  (Read 3694 times)
retrogamer
  • Last login:September 20, 2002, 10:31:59 pm
Only making a 1 player vertical cabinet which will have only 3 buttons for now. Should I end up hacking a keyboard or Sidewinder or just use an IPAC?  :D
tom61
  • Last login:September 18, 2017, 12:46:56 am
I'd go with the sidewinder or other gamepad hack. Keyboard hacking is a pain, and the I-Pac is overkill for a one player cab.
retrogamer
I understand that you need 2 connections for each button/joystick. With the sidewinder hack, do you connect all the grounds together and can this be done with a keyboard ground as well?
You can with the sidewinder but not the keyboard.
The keyboard is a matrix, in other words both wires are live.
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
you should go with sidewinder hack for 1 player...
and yes, you can daisy chain all your ground together.
Another Brilliant mind ruined by education....  :p
jelloslug
  • Last login:May 25, 2005, 03:55:59 pm
  • Splut!
    • Jelloslugs Arcade
Actuall on some keyboards (if you lucky) you might be able to find enoungh keys that hook to spot on the matrix that you could run a common between them all.
MameFan
I'll let everyone in on a little secret...
The USB Gravis GamePad Pro controller (charcoal grey in color) is a PERFECT controller to hack.
Why?
-  $14.99 normal price at BestBuy (occassionally on sale for $9.99 !!!!)
-  14 DISCRETE Digital Inputs (4 Direction, 4 primary button, 4 shoulder buttons, 2 "start/select" buttons)
-   Long Cable
-   USB, not old gameport (allows up to FOUR pads connected to most motherboards that have 4 ports, without need to cascade and the problems that ads)
-   NO special software if you use Windows (no sidewinder calibrating/drivers)
Disadvantages:
-   NO Pure DOS USB  support.
For your project, I'd just go with something like this.
If you make removable control panels, on sale at $10 each, it's CHEAPER to buy 1 pad per panel, and then just disconnect the USB rather than buying molex connectors to disconnect the panel from it's mate like others do when they hack into say the $45 IPAC's.
retrogamer
Why?
-   Long Cable
Disadvantages:
I have one of these pads but I've been to a site that has sidewinder's for $4.95 each and from what I've read, sidewinders are easy to hack because of already made connection points. Is the USB Gravis easy as well?  Thanks
