Main > Software Forum
MAMEWAH most wanted...
Minwah:
--- Quote from: Magnet_Eye on May 20, 2004, 08:22:25 am ---I mean, more than just a background image and the objects on top. how about a background, then objects, then ability to lay other images or objects on top of those? multi-layered.
AracdeFX had this, and it was key to making great skins.
Not likely, unfortunately it just wouldn't work using VB's GDI :( That's partly why Howard ditched Lazarus and made Dragon King I believe...
Onji:
--- Quote from: Minwah on May 19, 2004, 07:29:41 pm ---
If you get stuck let me know and I'll give it a go, I've been meaning to do it anyway...
Well I messed with it last night, I got it halfway working, It will launch a game, then when the time interval is up, it will attempt to switch to another game, but it just drops to the desktop. Not sure whats going on. I'm going to mess around with some settings tonight though.
Aceldamor:
--- Quote from: Minwah on May 20, 2004, 07:48:49 am ---
--- Quote from: Aceldamor on May 20, 2004, 01:37:49 am ---One question. Can you set Mamewah to play an intro movie before you get into the main skin?
Example: I have the short version of Arcade 84 (thanks to Dave Dries) and would like it to run before the main interface comes up.
If it doesn't do it now...can you put that on the "to do" list? ;D
*edit*
Also wondering if you can assign key's to gamelists...
Example: I would like to use a launchpad and have buttons for each emulator..when I hit the button I get that emulators game list.
Can't do either atm :(
I'll be adding movie screensaver/preview support at some point so I'll look into that then.
I'm not sure the best way I could add shortcuts for each emulator as it would now require 50 keys!
Heh..I don't mean a button for every emulator, I mean being able to assign a hotkey to launch a gamelist for an emulator....I personally don't use 50 emulators....good god that is too many. I only use about 10ish..(which is still horrible) ;D
SaiNRuB:
--- Quote from: Onji on May 20, 2004, 01:51:30 pm ---
I have the same predicament Onji, here is the thread i was using for feedback in case your interested.
Help needed for Emusaver 3.0 please
Minwah:
--- Quote from: Aceldamor on May 20, 2004, 02:54:35 pm ---Heh..I don't mean a button for every emulator, I mean being able to assign a hotkey to launch a gamelist for an emulator....
Sorry I don't know what you mean? Isn't that the same thing?
--- Quote ---I personally don't use 50 emulators....good god that is too many. I only use about 10ish..(which is still horrible) ;D
I agree (I use 3 atm), but I'd still have to make whatever functionality available for all 50 possible emulators...
