Main > Software Forum
MAMEWAH most wanted...
Pages: << < (19/24) > >>
Magnet_Eye:
Hey Minwah, are we gonna get some layer usage with the Layouts anytime?
Aceldamor:
Minwah.....Lovin' the updates to far, thanks for a great fe....
One question. Can you set Mamewah to play an intro movie before you get into the main skin?
Example:  I have the short version of Arcade 84 (thanks to Dave Dries) and would like it to run before the main interface comes up.
If it doesn't do it now...can you put that on the "to do" list?   ;D
*edit*
Also wondering if you can assign key's to gamelists...
Example: I would like to use a launchpad and have buttons for each emulator..when I hit the button I get that emulators game list.
is that possible?
Minwah:
--- Quote from: Magnet_Eye on May 19, 2004, 10:33:30 pm ---Hey Minwah, are we gonna get some layer usage with the Layouts anytime?
Can you explain a bit more please  ???
Minwah:
--- Quote from: Aceldamor on May 20, 2004, 01:37:49 am ---One question. Can you set Mamewah to play an intro movie before you get into the main skin?
*edit*
Can't do either atm :(
I'll be adding movie screensaver/preview support at some point so I'll look into that then.
I'm not sure the best way I could add shortcuts for each emulator as it would now require 50 keys!
Magnet_Eye:
--- Quote from: Minwah on May 20, 2004, 07:09:31 am ---
I mean, more than just a background image and the objects on top. how about a background, then objects, then ability to lay other images or objects on top of those? multi-layered.
AracdeFX had this, and it was key to making great skins.
Go to full version
