Author Topic: Issue Loading ROMS w/ MAME32  (Read 1133 times)
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« on: April 22, 2004, 02:30:02 pm »
Is this a common problem? One one of my computers MAME32 will load but as soon as I select a game the screen freezes with "garbage" and I have to reboot. I'm running a 500MHz PII with 256MB RAM and a primitive Trident 4MB grapics card on Win98SE. Maybe a drivers issue?
I also thought that maybe running a command line version of MAME with a FE would work as well. Any suggestions?
SirPeale
  • Green Mountain Man
Re:Issue Loading ROMS w/ MAME32
« Reply #1 on: April 22, 2004, 02:44:06 pm »
What game are you trying to run, or is this all games?
flampoo
  • BYObsession
    • flampoo
« Reply #2 on: April 22, 2004, 10:33:45 pm »
It's all the games. And they're all pre-1990. Nothing too taxing on the computer.
SirPeale
« Reply #3 on: April 23, 2004, 07:56:10 am »
On board graphics/sound?  Version of DirectX you're using?
Also, yes, do try the command line version.
flampoo
  • BYObsession
    • flampoo
« Reply #4 on: April 25, 2004, 07:33:50 pm »
I've narrowed down the issue... I've got DirectX 7 loaded on the machine. When I run a display test on DirectDraw and it gets to the fullscreen test, the screen goes to garbage.
I reboot, repeat the process except instead of running the DirectDraw test I run the Direct3D test. It immediately goes to garbage.
For some reason I can't install version 8 (the file is always corrupt, even after different downloads from different sites) and because this is a stand alone pc I can't use the websetup version.
I get the same results when running MAME32 and any command line version of MAME. However, I considered turning off the DirectDraw and Direct3D rendering from the command line version. What will happen then?
Am I missing something?
SirPeale
« Reply #5 on: April 25, 2004, 08:23:57 pm »
You considered doing it, but acutally haven't done it?  It's just a checkbox, you know.  You can always recheck it.
