Main > Software Forum
MAMEWah / Cab users / Advise !
Pages: << < (2/3) > >>
Lilwolf:
catver.ini is MUCH more useful for filters.
But I use a bunch in jfront because I cache the default.cfg in mame and load them based on game info.  So I can configure 2 8way joysticks with 6 buttons once (all the streetfighter games that have the punchs and kicks swapped)... or the 4way games once... or all the dual 8ways once.
But other then that, Some people like vertical games and horizontal games seperated.
Minwah:
Thanks for the comments.
I do plan to add catver compatibility (the 'cat' part at least :)).
As for the MP3 thing, it is a good idea but I don't how to do it just yet  ;)  Plus I don't even have any MP3's!  Maybe I'll figure it out when I've finished doing some of the 'more important' stuff.
SirPoonga:
or if you are like me you store all that info in a database:)
Hey, you FE screws up my refresh rate.  I run 1152x864 at 75hz.  When mamewah quits I am running at 60Hz.
Howard_Casto:
The problem with databases is that they have to be maintained.  I've found a simple text file to be much more managable and users like it because they can look in it and see what is going on.
SirPoonga:
Yeah, they need to be maintained.  Unless you put a mechanism to load new listinfo stuff:)
Just an answer to if you have memory issues.  But then you have SQL drivers installed in mem so it really makes little difference.
Go to full version
