Main > Software Forum
Ultracade ==> UltraStyle
Pages: << < (8/9) > >>
froggerman:
I am trying to install Ultracade to see how it works and I am having some problems. I also noticed something in the config program. Changes must be saved on each page. If you make pages on the first page, Ultrastyle options and then switch to the second page, MyRomInfo options and then click on Save Config and close the application all changes on the first page will be lost.
When I try to run Untracade I receive the following error:
Unable to create 3D Scene
Has anyone else seen this problem? Or have any suggestions on how to fix it?
ultrastyle:
froggerman,
 I am guessing it's 1 of 2 things.
 1. old video driver, if this is the case try to download the latest driver for your video card
 2. old video card, if this is the case try to swindle the latest video card
if #1 doesn't work, #2 probably will.
  Chris
ultrastyle:
Also,
 froggerman is correct about saving the configuration information. each of those save buttons are for the specific page you are working on. I made them all look the same for asthetics. Maybe i will change the button names so as not to confuse future generations.
Oldskool:
Looks great so far!
RayB:
I know this thread is a little old, but I needed to comment on Ultrastyle's sarcastic remark:
I *May* be able to do this, i'm not sure. I am sorry that you have to be momentarily reminded that you bow to the microsoft god, as we all do.
See, if you build a MAME machine and you want it to look/act like an arcade machine (perhaps even coin operated  ;D  Perhaps have it set up in a Public Place for example) then no, you certainly would not want a Windows desktop flashing up.
Go to full version
