Author Topic: Using crt emudriver for crt tv as a monitor  (Read 6138 times)
Dratliff8896
  • Last login:June 21, 2025, 10:34:10 pm
« on: June 02, 2025, 12:24:10 pm »
Im trying to build a windows xp machine with an x300 video card with an s video out. But when ever i try to use the emu driver it makes everything to big to read and wont allow videos to play. How can i remedy this?. Or am i screwed on this idea.
buttersoft
  • Last login:March 04, 2026, 09:09:23 pm
  • Is running at 15kHz
Re: Using crt emudriver for crt tv as a monitor
« Reply #1 on: June 03, 2025, 10:46:44 pm »
crt_emudriver and the S-video output will be mutually exclusive. I would set up a regular winXP install and then plug in your S-video and try things that way. That should get you started, anyway.
Zebidee
  • Last login:Today at 06:12:14 am
« Reply #2 on: July 05, 2025, 05:00:48 am »
What Butters says. That'll get you started
The picture quality will be mediocre from the s-video out as you'll only be able to get one resolution (640x480i?). This is great for what the card was designed for (showing videos and presentations at work training sessions and suchlike), but not great for gaming where you want stuff like 240p, and flexibility to set video modes and refresh rates.
You could try the deprecated Emudriver 1.2b for XP, which I *think* is compatible with your card, and taking the RGB video out of the VGA head (as normal) to a transcoder box. I think Jam makes one for s-video ("Wakabavideo", https://www.ebay.com.au/itm/174151197805) but he is often out of stock. Otherwise, maybe a GBS-8200 or something.
RGB mod your TV (or component-mod it and use a GreenAntz RGB-component transcoder!) FTW.
