Author Topic: Wheel2XInput, designed for mapping wheel and wheel accessories to XInput  (Read 59103 times)
nugarp
  • Last login:November 09, 2025, 11:22:06 pm
Re: Wheel2XInput, designed for mapping wheel and wheel accessories to XInput
« Reply #40 on: October 23, 2025, 11:11:30 pm »
Hello, I understand you can use multiple inputs and assign them in Wheel2XInput. I see an example for overriding one GUID with another for say a specific button but here's what I'm trying to accomplish...
I have a TMX racing wheel and the TH8S shifter. I want to map the shifter to currently mapped dpad and paddles on the wheel in the json, not override it, but have both inputs working. How would I code that into the json? I have used the trace app to pull the GUID and button numbers, so just need to know how to inject that info into the json.
Map multiple inputs to the same output, it will work as you want by default as I assume these are digital inputs and not analog that you are making as your targets.
Another way to say this: you can have the same targetButtons or targetDpads for multiple defined inputs.
Wheel2XInput | HDRecoil | LeaderLamps | NetLauncher | Discord | Youtube
Eckers569
  • Last login:November 11, 2025, 06:21:21 pm
« Reply #41 on: November 09, 2025, 09:24:49 pm »
I think the code for mapping multiple GUIDs to a single button in the earlier reply might be wrong. I couldn't get it to work.
I tried a mixture of that and Copilot and came up with the following which did the trick for me.
Same Gear shifter as yours,  but my wheel is the TS-PC Racer. Pasted the full json so you can see it in context, but at the end of the 'buttons' section I've mapped A,B,X,Y to 0,1,2,3 on my shifter (gear changes in Daytona!). The plus side is the same buttons still work on my wheel.
Program is especially useful for emulating systems like Dreamcast, where the controller has limited buttons so you need to multitask. Crazy Taxi for example uses A and B to navigate menus but are then gear shifts in game - so I wanted wheel shifting to function while also retaining the face buttons for navigation:
  "guid": "00000003-044f-0000-89b6-000000000000.1",
  "enableForceFeedback": 1,
  "enableRumble": 0,
  "centeringForce": 50,
  "largeRumbleMagnitude": 80,
  "largeRumblePeriod": 120,
  "smallRumbleMagnitude": 50,
  "smallRumblePeriod": 60,
  "effectDuration": 1000,
  "effectAntiDeadzone": 0,
  "detectControllerReconnects": 1,
  "pollInterval": 16,
  "buttons": [
      "button": 0,
      "targetButtons": [ { "button": "A" } ]
      "button": 1,
      "targetButtons": [ { "button": "B" } ]
      "button": 2,
      "targetButtons": [ { "button": "Y" } ]
      "button": 3,
      "button": 4,
      "targetButtons": [ { "button": "Back" } ]
      "button": 5,
      "button": 8,
      "targetButtons": [ { "button": "Start" } ]
      "button": 9,
      "targetButtons": [ { "button": "X" } ]
      "button": 0,
      "guid": "00000003-044f-0000-60b6-000000000000.1",
      "targetButtons": [
        { "button": "X" }
      "button": 1,
      "targetButtons": [
        { "button": "A" }
      "button": 2,
      "targetButtons": [
        { "button": "Y" }
      "button": 3,
      "targetButtons": [
        { "button": "B" }
  "dpads": [
      "dpad": "up",
      "targetDpads": [ { "dpad": "Up" } ]
      "dpad": "right",
      "targetDpads": [ { "dpad": "Right" } ]
      "dpad": "down",
      "targetDpads": [ { "dpad": "Down" } ]
      "dpad": "left",
      "targetDpads": [ { "dpad": "Left" } ]
  "axes": [
      "axis": 0,
      "config": {
        "inverted": 0
      "targetAxes": [ { "axis": "LeftThumbX", "deadzone": 0, "antiDeadzone": 0, "linearity": -30, "low": -110, "high": 110 } ]
      "axis": 2,
      "config": {
        "inverted": 1
      "targetSliders": [ { "slider": "RightTrigger" } ]
      "axis": 1,
      "config": {
        "inverted": 1
      "targetSliders": [ { "slider": "LeftTrigger" } ]
Great little program by the way Nugarp. Once I've got my head around it looks like it can replace x360ce in a lot of similar user cases.
« Last Edit: November 10, 2025, 12:03:09 pm by Eckers569 »
nugarp
« Reply #42 on: November 09, 2025, 11:22:06 pm »
Cheers. The way you have done it is correct, as you noticed :).
I have a 1.6 beta that will send ffb or rumble to multiple devices, so if anyone needs that, find me on discord. It should also support hotswapping of the config.
Eckers569
« Reply #43 on: November 11, 2025, 05:28:46 pm »
Nice one, thank you. I will check out the discord ASAP.
« Last Edit: November 11, 2025, 05:38:47 pm by Eckers569 »
ark216
  • Last login:Yesterday at 07:01:15 am
How does this software differ from x360ce. I would really like to test this out with my G29 but since it does not have GUI and is just code based it looks a bit intimidating. Are there any easy user friendly guides where i can follow? I did check it's README, i found it to be a bit confusing.
