| Main > Project Announcements |
| 15-ish Years in the making |
| << < (5/11) > >> |
| bobbyb13:
--- Quote from: rbarr110 on January 21, 2022, 01:45:02 am --- --- Quote from: Gilrock on January 20, 2022, 12:41:55 pm ---Hey when you post here you need to make sure we can live with it also. Those triangles need to go...lol. --- End quote --- I plan on making new ones, but for testing purposes they can stay. The more I look at them the more I cant look at them. --- End quote --- :lol |
| pbj:
Just cover them up with collage of arcade and console characters. Nobody will ever know. |
| rbarr110:
The frame of the control panel getting cut out. |
| rbarr110:
The axle for the panel. The flanged bearing fit perfectly inside 1-1/4" PVC pipe and the flange stops the bearing from going too far in the pipe. Used use 3/4" steel tube to tie the PVC to the bearing in my HDPE guide blocks. I just need to go to the hardware store and pick up a couple of shaft collar locks to hold the steel tube in place relative the the bearings. |
| rbarr110:
Drilled some pockets for the pocket screws and got the lower half the cabinet together for testing. |
| Navigation |
| Message Index |
| Next page |
| Previous page |
