Main > Project Announcements
15-ish Years in the making
<< < (11/11)
rbarr110:
Photos of the test setup and how the 4 wires (ipac power, ipac USB, USB hub, USB hub power)from the control panel are routed so the CP can rotate the needed 270 degrees to access the 3 panels.
rbarr110:
So long time no post/updates, but to be honest I fell into the trap where you get the cab playable without finishing the wood work and become lazy.  I also fell down the light gun rabbit hole and messed around with trying to get wiimote cameras to work, but didn't have any success.  Fortunately the DFrobot cameras I ordered in January came in and I was able to wire up a gun and mess around with it.  Started with a guncon2 shell, but found a printable case that was easier to work with as it was designed for using a Gun4IR setup.  So rather than work on a cab, CNC'ed my own pcb's and put time into the light gun and it works quite well.  Time to finish the woodworking before the wife gets any more pissed about an unfinished cabinet.
rbarr110:
Been busy, been lazy, been sidetracked, etc, etc.  I haven't worked on the cabinet in a while and when I did, I didn't post updates.  Anyway, after messing around with light guns, I made a new gun and working on the second now (Odcon shell with Gun4ir).  Anyway, still need to decide on a marquee and finish the lower panel.  The lower panel will have "holsters" for the guns and then I can call the cabinet complete.  I want to redo the Launchbox setup and separate the options based upon the different CP on the cabinet.
Zeosstud:
Fantastic project. How big is your CNC, 4x4 or 4x8? just curious, I am pretty close to pulling the trigger on a OneFinity Elite Foreman, which is a 4x4 setup.
Zeosstud
rbarr110:
It cuts an area 4 ft x 5 ft.  Its a DIY CNC at Joescnc.com
Navigation
Message Index
Previous page
Go to full version
