Main > Monitor/Video Forum
Kortek 19 inch CRT Chassis for arcade AC INPUT on KTN20
simondwilliams:
I am from Canada in the quebec province
grantspain:
ok no problem, if you were uk based the degauss would have wired direct to 240vac but i imagine you are same as usa on 120vac so the link wires will be correct for you on the ac input connector
