Main > Monitor/Video Forum
Kortek 19 inch CRT Chassis for arcade AC INPUT on KTN20
simondwilliams:
I removed the broken ceramic it is a 30W 12 ohm YUMI ceramic written on it :) It was connected to R601...
I cannot find ic601 but see a transistor at q601. Photos attached
grantspain:
next steps are to replace the resistor with correct value, check the bridge rectifier with a multimeter for any shorts and do the same with q601
simondwilliams:
Thanks for your help :)
ok order de ceramic from amazon... Now for the transitor check I google and found a video will get back to you as for the bridge rectifior where is it ?
grantspain:
D601 top right corner, almost as common as flyback failing these chassis
grantspain:
are you in the uk as that chassis would be rare in the usa imo
