Author Topic: Old School Mamewah help.  (Read 3466 times)
killbill
  • Last login:March 03, 2026, 04:31:25 pm
  • When I die, I want to go to arcade heaven!
« on: June 25, 2021, 10:41:16 pm »
Hey Guys,
Had someone over playing on my cab and they must have hit a certain combination of buttons because now all my MAME game titles are showing up as the rom name, not the game title, in Mamewah.
I built it so long ago, I can't remember what to do to fix this in Mamewah.
Any help from you fellow old school guys would be very appreciated.
« Last Edit: June 25, 2021, 10:43:41 pm by killbill »
Zebidee
  • Last login:Yesterday at 08:33:57 pm
Re: Old School Mamewah help.
« Reply #1 on: June 26, 2021, 02:33:32 am »
No backups?
You can generate your lists within the MameWAH menu interface by bringing up the options. By default you press P2 Start to bring up the options menu and there is a "Gamelist Options" item. You can use that to switch to other lists, generate lists and add/remove games from the lists.
You should generate the "All Games" list first, then and other lists you might have like "Favourites", "Classics", "Vertical", "Beat em up", "Shmups" etc
MameWAH has problems with generating lists from later versions of mame (is to do with the xml file format), although there is a version floating around where the issue has been fixed. Sorry for being vague, I can't remember all the details either, it has been a year or so since I redid my own Mamewah lists. If MameWAH won't generate lists for you, a 3rd party list generator like ROMlister can help.
killbill
« Reply #2 on: June 26, 2021, 03:42:14 am »
Hey Zebidee, thanks for the info. Yeah, I think I'm running MAME .79, so it shouldn't be an xml problem. That kid did something, he must have switched a setting in Mamewah by mistake. Weird.
Zebidee
« Reply #3 on: June 26, 2021, 04:18:42 am »
"Kids" can break anything, probably did it by accessing the gamelist options menu like I described above.
You can probably lock it out somehow but I've never bothered myself. Once you sort it out, keep a backup of your MameWAH directory in case it happens again.
