Main > Monitor/Video Forum
Looking for some help whit monitor whining noise.
princess prin prin:
Two solder points on the bottom. Dry brush it or use a degreaser and water.
MKFan4Life:
I think you got confused about the toothpick. Correct me if I am wrong, but that was a trick Bob Roberts mentioned once to quieten down "singing" flyback transformers with loose cores isn't it? I have one of those in a K7400 that went down. Got a new flyback for it and need to get that replaced soon. I could put pressure against the flyback with a plastic tool and it would change it's tune, so it makes sense a toothpick shoved underneath at the correct spot might quieten one down a bit.
