Main > Monitor/Video Forum
Monitor Sizing Help
bobbyb13:
Zebidee is a long time forum member with a cool new transcoder.
http://forum.arcadecontrols.com/index.php/topic,164245.msg1730133.html#msg1730133
Are you trying to connect an original arcade pcb or a PC or Pi?
bsoder52:
I'm initially going to run a Jakks Pacific plug n play set. Plan to watch the marketplace for a reasonable 1up Buck Hunter and then put those guts into this cabinet. So basically for those I need component in for the Jakks Pacific plug n play and then HDMI for the 1up guts later.
bobbyb13:
Ah... it's the BBH cabinet.
Not sure I have meaningful info for you with that track then, but the search engine here is working again now so have at it!
Zebidee:
--- Quote from: bobbyb13 on April 05, 2021, 06:41:07 pm ---Zebidee is a long time forum member with a cool new transcoder.
GreenAntz makes it easy to repurpose a standard CRT TV with component/YPbPr inputs as an arcade monitor, supergun or retrogaming display. Easy to mount in a cab. It comes in VGA and SCART flavours. Easy to adapt for most game PCBs :D
bsoder52:
Good to know! I'll cross that bridge when I get to it. I purchased the geekworm lvds to HDMI adapter already too..
