Author Topic: GroovyMAME 0.287 - Switchres 2.22b  (Read 459025 times)
arc11
  • Last login:May 27, 2026, 09:59:50 am
Re: GroovyMAME 0.287 - Switchres 2.22b
« Reply #520 on: May 13, 2026, 01:15:54 pm »
Last year while I was searching for a workaround, I found odd in the lines :
    // determine the scale factor
-   float scale_factor = target_font_height() * scale / one_to_one_line_height;
+   float scale_factor = std::min(target_pixel_height / float(raw_font_pixel_height) / options().font_rows(),
+                        target_pixel_width / float(raw_font_pixel_height) / options().font_rows());
that a division is made between
 target_pixel_width
and raw_font_pixel_height
if I understand correctly this expression the second line should be
target_pixel_width / float(raw_font_pixel_width) / options().font_collumns()
I don't know if  raw_font_pixel_width and font_collumns exist, i just put meaningful names
just an idea....
  • Last login:May 27, 2026, 05:38:56 pm
« Reply #521 on: May 21, 2026, 12:51:55 pm »
Hi arc11,
 target_pixel_width
just an idea....
Yes I understand why the code looks wrong. But it is right. There's no such thing as font pixel width (neither font columns). The only property that's defined for fonts is their pixel height.
The problem is this code in GroovyMAME is meant for integer scaling of bitmap fonts (.bdf fonts). Currently MAME defaults to a true type font that doesn't work so well when integer scaled, specially at extreme pixel aspects as the one you're using for the menu (768x240).
So probably I should make uismall.bdf the default in the provided mame.ini to avoid this problem in the future.
I took some time to replicate (sort of) your setup here, this is how GroovyMAME looks when -uifont uismall.bdf is used. The mode on screen is 768x240 (portrait / rotated).
arc11
« Reply #522 on: May 27, 2026, 10:00:19 am »
Thanks for the reply
with this way of launching mame, the font is readable, but the menu is not as good as with the original mame code
« Reply #523 on: May 27, 2026, 04:58:02 pm »
Hi arc11,
The picture should look exactly like the one I posted (I configured my system with your resolution to do the test). If it doesn't, there must be something else broken with your configuration.
EDIT: Make sure to set font_rows 30 in ui.ini.
« Last Edit: May 27, 2026, 05:39:26 pm by Calamity »
