Main > Monitor/Video Forum
Searching help to use the arcade monitor of a virtua striker 2 cab
grantspain:
also white wire on japanese cabs is ground so you need to swap the white and blue/white wires on the rgb
ame.masia:
Thanks for this suggestion! I was wondering about that white cable that was not corresponding with other wires connected to it.
I didn't had any success yet with my complex setup, I'm waiting to have a pandora's box and then try with an easier setup to find a solution.
