Main > Monitor/Video Forum
Jamma XXXX Game Board won't connect to monitor.
Pages: << < (2/3) > >>
grantspain:
the jamma type supply just powers the top board , the led looks to be lit in your photo so likely is working
the motherboard part of the unit is powered by a standard atx type supply, probably find that is faulty or the power cable fell out
a multimeter will prove everything
Landspyker:
I disconnected the jamma power supply but the green led light still turns on. Big confusion.
Also the monitor is Norma, this website just smooshed the image so it looks small and wide but it's normal.
Landspyker:
I connected a new power supply for the jamma board but still have the same issue. Gonna have to try a computer power supply now.
grantspain:
whats the monitor btw, it looks like a nanao ms8-26
check the neck card is fully home
Mike A:
Did you contact the seller?
Go to full version
