Main > Monitor/Video Forum
Jamma XXXX Game Board won't connect to monitor.
Landspyker:
I fixed it! Turns out it was the power supply for the Jamma board (not the PC PSU). Seems to be a very common issue.
Titchgamer:
--- Quote from: Landspyker on July 22, 2020, 12:45:57 am ---I fixed it! Turns out it was the power supply for the Jamma board (not the PC PSU). Seems to be a very common issue.
Glad you are sorted but what was the actual issue?
Low voltages or just a naff PSU?
It may help the next person who finds this thread with the same issue :)
Landspyker:
I believe I just wasn't getting any output from the power supply. Once I swapped it with a new one it worked fine and has been going strong ever since
