Arcade Collecting > Merit/JVL Touchscreen
JVL Conquest Factory Reset Failed. Error code 2
lilshawn:
not all cards are created equal. you can put 2 cards of the same size side by side, and see a few kb difference between them. could be that the card you got to replace it is just under what it considers "64mb".
a 128 or a 256mb will work just fine 512...maybe... it could depend on the motherboard if it detects it properly or not.
side note funny story - i had some software that said you had to have 512mb of ram to install... system had 1gb... i guess how it read the ram amount made 1024 appear smaller than 512.
kjtemp:
Yes I connected the new CF card to my reader and it shows as 60mb. The motherboard is a j10. Maybe get a 128mb and see?
kjtemp:
Might of found my solution. Seems itouch 7 only needed the 64mb CF but itouch 8 needs 512mb CF. Since this has itouch 8 maybe get a 512mb CF card?
https://forums.arcade-museum.com/showthread.php?t=43345
kjtemp:
Does anyone know what the IO board does specifically? Does it do more than hold the software key and have the service button? I'm wondering if the eeprom the error is referencing is on the io board itself...
lilshawn:
the io board basically interfaces the physical world (coin switches, service switches, bill acceptor lines, etc.) with the computer. it also holds some configuration information for the program (games enabled or disabled, coin/bill accepter type/settings/values/ and whatnot)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
