Main > Project Announcements
javeryh's Woodgrain Cabaret Copy
Arroyo:
I believe that Javery is correct and these are 2V LED’s. At least the originals were. I discussed building a voltage divider for the ones I used on the flight stick in my thread to bring the 5V down to 2V:
http://forum.arcadecontrols.com/index.php/topic,156267.msg1644624.html#msg1644624
PL1:
--- Quote from: Arroyo on December 13, 2020, 11:28:41 pm ---I believe that Javery is correct and these are 2V LED’s. At least the originals were. I discussed building a voltage divider for the ones I used on the flight stick in my thread to bring the 5V down to 2V:
The 220 ohm resistor acts like R1 and the LED acts like R2 in your voltage divider diagram.
How did I know that a 220 Ohm resistor would work for this application?
--- Quote from: yotsuya on June 10, 2015, 06:38:37 pm ---How I do it:
Wire in a 220 resistor on the line going to 5v. Crimp on a quick disconnect.
Attach the QD to the + end of the Atari button LED terminal.
Hook up the other end to ground.
Turn the machine on, see the red lit button.
No worries.
Never burned out a LED button with the resistor connected.
javeryh:
--- Quote from: PL1 on December 13, 2020, 11:19:48 pm ---What you need is a 220 Ohm (or 160 Ohm), 1/4 Watt (or 1/8 or 1/2 Watt -- smaller wattage ==> thinner leads) current limiting resistor between 5v and the LED+ terminal.
Thanks guys. So if I buy THESE (100 LOL - I only need 2 max) I should be OK?
I would like to somehow pull the power from the iPAC2 - there are two trackball connections that I will not be using and there are pins labeled 5V. Could I use those for the LEDs?
I would run a wire from iPAC2 5V pin to the resistor and then the resistor to the positive side of the volcano button LED leads. I would run a separate wire from the negative side of the volcano button LED leads to the player 2 GND terminal on the iPAC2 (for ground). I realize this would mean as long as there is power to the iPAC2 the LED lights will be on. Would this work?
Also, which side of the resistor goes where? I assume it matters how it gets connected as it will be stepping down the voltage.
Sorry if this is ridiculously basic stuff... ;D
PL1:
--- Quote from: javeryh on December 15, 2020, 01:31:42 pm ---So if I buy THESE (100 LOL - I only need 2 max) I should be OK?
They are a bit of overkill, but those will work fine.
Each LED and resistor pair are only going to draw a total of about 20 mA so that's 100mW -- around 60mW for the resistor and around 40 mW for the LED.
(Watts = V * A ==> W = 5v * 20mA ==> 100mW)
Same resistor in a 1/4 W size:
https://www.amazon.com/EDGELEC-Resistor-Tolerance-Multiple-Resistance/dp/B07QK9ZBVZ/
An assortment pack will cover many future projects as well:
https://www.amazon.com/McIgIcM-resistor-Electronics-resistors-assortment/dp/B06WRQS97C/
https://www.amazon.com/Resistors-Assortment-Tolerance-Excellently-Breadboards/dp/B07D2Z45CG/
--- Quote from: javeryh on December 15, 2020, 01:31:42 pm ---I would like to somehow pull the power from the iPAC2 - there are two trackball connections that I will not be using and there are pins labeled 5V. Could I use those for the LEDs?
Yes. Those pins are designed to power the two LEDs of a trackball/spinner axis so they are perfect for this application.
--- Quote from: javeryh on December 15, 2020, 01:31:42 pm ---I would run a wire from iPAC2 5V pin to the resistor and then the resistor to the positive side of the volcano button LED leads. I would run a separate wire from the negative side of the volcano button LED leads to the player 2 GND terminal on the iPAC2 (for ground). I realize this would mean as long as there is power to the iPAC2 the LED lights will be on. Would this work?
Yes, you can either do it that way or you can connect one 5v line to the left side of both resistors in your diagram.
--- Quote from: javeryh on December 15, 2020, 01:31:42 pm ---Also, which side of the resistor goes where? I assume it matters how it gets connected as it will be stepping down the voltage.
There's no +/- polarity to a resistor so you can't install it backward. ;D
You may also want to use heat shrink like steps 1-3 here . . .
. . . and QDs like smalltownguy did here.
javeryh:
Scott - thank you for taking the time to provide such a detailed response. I just ordered the resistors and I'm looking forward to making this work! I have some shrink tubing so I will also try to make it as neat as possible. I should be able to finish the wiring this weekend. I'd love to have this playable but Christmas! :cheers:
