Main > Project Announcements
javeryh's Woodgrain Cabaret Copy
Pages: << < (102/156) > >>
javeryh:
--- Quote from: UnclearHermit on December 08, 2020, 08:35:18 am ---There's a longer shaft available, which would give you another 10mm without routing:
https://www.ultimarc.com/arcade-controls/joystick-accessories/ultrastik-360-long-handle-shaft/
Wow thanks.  I am ordering now.  It might make the throw a little weird since the center point will be lower than usual (by only 1/4" so not that much) but I'm sure I'll get used to it.  I was looking for an excuse to order a spinner top so I guess I'll do that too - I just wish I could get one in white.
morton:
That's a beauty control panel. The whole thing is minimalist whilst still packing a lot of abilities. The art is perfectly balanced with it all.
This is the third time in as many days I have read mention of the longer shafts being used on thicker control panels. I was initially torn on what to do in my situation and think I may consider the same. It definitely would ensure minimal risk in damaging the work you've already done. My only question in regard to the longer shaft it... Does the stick length really affect throw feel much in games?
javeryh:
--- Quote from: morton on December 08, 2020, 03:24:09 pm ---That's a beauty control panel. The whole thing is minimalist whilst still packing a lot of abilities. The art is perfectly balanced with it all.
Thanks - really appreciate the nice comments.  So far, the whole project is coming out exactly like I see it in my head...
I have never used a longer shaft on any joystick but the more I thought about it, the more it made sense to give it a shot.  I was planning on routing out 1/4" max from behind the panel.  That isn't a lot at all but I couldn't go any deeper or else the 4 screws might not hold or they might accidentally poke through the art (which would make me nuts).  So 1/4" is all of the height I'd be gaining.  That's nothing.
The longer shaft adds 10mm or approximately 3/8".  I don't think the throw will feel all that different.  Maybe it will but I'm giving it a shot.  Worst case scenario is that I end up routing out the material but I would really have to hate it.  I ordered from Andy this morning - I just hope it gets here soon!
javeryh:
Longer joystick has arrived!  $32 shipped from the UK.  Pricey but whatever.  I'm hoping to install it tomorrow or over the weekend.  I'm a little worried about the throw but I think it will be fine.  I'm not too picky.  To do:
1. Install joystick
2. Wire everything
3. Figure out how to attach CP to cabinet.
4. Order and install 1/4" tinted glass
5. Turn coin return into pushbutton
6. Figure out where to put volume knob from speakers
7. Final tweaks to computer (boot up, hide windows, etc.)
I'm sure there is more I'm not thinking of but this is basically the punch list.  Anyone have any recommendations for a decent glass shop that will cut to a custom size and not charge an arm and a leg?
leapinlew:
No suggestions for online glass since I have always used a local shop. I’m curious what your local shop vs online shop research pulls up.
Go to full version
