Main > Lightguns
Mamehooker Settings For positional gun recoils (Steel Gunner Hammer Guns)
<< < (3/3)
Howard_Casto:
It's just something I made up to work with mamehooker.  Documentation is in the readme.txt and the website.  Scripts are the exact same mamehooker commands you do in the ini files, only functions are separated by a new line instead of a comma.
frankrizzo2:
Okay. Thanks for the info Howard! I'll mess with it today.
frankrizzo2:
So what's the best way to use the loop function? Do I use the lfs and call up a prewritten script? I have one made up that I'll post tmw and I think I have it correct but I want to make sure. I need to add delay between every "on" "off" so do I set it to fire on, wat 20, fire off, wat 20, fire on, wat 20? I want a consistent delay between each "on" "off" shot that the gun fires if that makes sense?
Afterburner1970:
Hi Howard
Hope you get to see this, as Im going down the same road as the original poster, and hoping you can help please?
Using an APAC for the gun movement, and a PAC drive to hook. Only difference is I'm using a revolution x gun.
I finally got mamehooker to see something, but it doesnt seem to be doing much. Recoil is stuck on 0
Hoping this screenshot will help, and you can offer some advise?
Thanks in advance
Afterburner1970:
Hi Howard
It only shows the outputs if I exit Mhooker (MAME game still running) then restart MHooker, then click on Mhooker in the taskbar….
Recoil is locked on zero under “outputs”
Navigation
Message Index
Previous page
Go to full version
