Arcade Collecting > Merit/JVL Touchscreen
Megatouch Force Radeon ghost touch problems
mahkeymike:
Yes the wires run along either the top or the edges of the overlay. There should be 5 wires soldered on all 4 corners of the overlay and all run to one corner. In my experience its usually the solder joint right where all the wires meet since that is the wire and joint that gets moved around the most when removing/replacing a monitor/overlay.
Fordman9870:
IS this the norm wire position for running the wire back to the controller box?
lilshawn:
if it is, i typically reroute it... not.... through the high voltage cage of ghost touches. it's pretty sensitive to static and stuff so i tend to keep it away from HV and the AC power cables.
Fordman9870:
What would be best way to reroute? this cable is an all in one to a controller box and can be unplugged. i can post more pics if necessary
lilshawn:
--- Quote from: Fordman9870 on December 18, 2019, 11:30:05 am ---What would be best way to reroute? this cable is an all in one to a controller box and can be unplugged. i can post more pics if necessary
i would just pull all the cables out of inside the monitor area and just lay it outside coiled in the top part and tuck it under the side cover. there is a tiny bit of room, but not much on that side.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
