Author Topic: What type is this capacitor? TRACON 10/50  (Read 4193 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
« on: August 30, 2019, 06:11:54 am »
Hi
I am trying to restore the original power supply for my Hard Drivin upright.
The fault is that there is no volts at all at the PSU. (fuse is OK)
So far i have changed nearly all the electrolytic caps, but there is one cap at location C24 I am unable to determine the type of..
Maybe someone know what type this cap below is, the naming on it is TRACON 10/50
grantspain
Re: What type is this capacitor? TRACON 10/50
« Reply #1 on: August 30, 2019, 06:47:22 am »
there is no c24 on the schem, you sure that not a coil- looks like a coil
mourix
  • Last login:September 13, 2025, 06:23:32 pm
« Reply #2 on: August 30, 2019, 01:32:40 pm »
Considering the negative side marking, I'm pretty sure it's a 10uF 50V cap. You can verify this with your multimeter in capacitor mode.
  • Last login:Today at 02:41:28 am
« Reply #3 on: August 30, 2019, 02:02:07 pm »
The other capacitor-related marking is the partially visible "105°C" in the second pic -- standard for high-temperature rated caps.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: September 01, 2019, 03:42:55 pm »
You have a 10 uf @ 50 volts radial electrolytic capacitor.
perjmolsen
    • My gameroom
« Reply #5 on: September 02, 2019, 03:25:37 am »
HI All
Thatks for all your replys! :)
Now i know that it is a 10 uf 50V   :applaud:
Now i just need to find a S2800B Thyristor - when I test that component in my china tester it fails the test.
perjmolsen
    • My gameroom
« Reply #6 on: September 07, 2019, 07:27:34 am »
Hi All
I need you again :)
I have found this "UA43 1AWC" who is dead.. but I cannot find any information for a replacement, or the component in the parts list.
The component is at location IC1
Can anyone help me in what component that i can use as an replacement?
« Last Edit: September 07, 2019, 07:42:39 am by perjmolsen »
« Reply #7 on: September 07, 2019, 06:44:08 pm »
Looking at the schematic above, it looks like IC1 is the Zener diode on the left side, 2/3rds of the way down.
The schematic is a little hard to read, so you might want to confirm these connections on the PCB.
- One trace from IC1 should go to R18 and R20.
- Another trace from IC1 should go to R22(?).
- The third trace from IC1 should go to R21 and C12.
I only see one Zener diode on the parts list, so that looks like a good place to start or the schematic labels IC1 as a TL431.
A TL431 is an adjustable Zener diode also known as a  programmable shunt regulator.
« Last Edit: September 07, 2019, 06:48:09 pm by PL1 »
Ken Layton
  • Guru
  • Technician
« Reply #8 on: September 15, 2019, 01:44:42 am »
It's a TL431 or a UA431.
