Main > Monitor/Video Forum
Wells Gardner D9400 vertical is off. Looking for help
Pages: << < (2/4) > >>
grantspain:
you do have one other option if that don't work- connect a keyboard and mouse, once game has booted press windows key and then shut down gvr then mouse right click the screen anywhere and use nvidia settings to adjust it
vargas14617:
--- Quote from: grantspain on August 02, 2019, 06:27:18 am ---i don't think the yoke has dropped otherwise you would have purity and convergence issues
maybe try factory mode, to enter the factory menu turn the monitor off. Hold the buttons 'OSD' and 'Key +' and turn it on- i think this is correct, its been a long time since i did this
I got into this menu but it did not help.  Do you know where I can get the default numbers because I messed up the sides.  I don't think its a collapse because the bottom goes beyond the screen. the other suggestion did not work.  I appreciate your help.  any other suggestions?
grantspain:
there are aren't any default numbers as such, how did you mess the sides up unless you restored factory settings which is not the same as accessing factory menu
accessing factory menu gives you more adjustments and greater ranges
anyway post a photo of a screen shot and i can tell you what to adjust
vargas14617:
--- Quote from: grantspain on August 05, 2019, 01:55:44 am ---there are aren't any default numbers as such, how did you mess the sides up unless you restored factory settings which is not the same as accessing factory menu
So this is what the picture looks like now. I reduced it to show the sides
grantspain:
so that looks simple enough to me
trapezoid
pincushion
vertical shift
vertical size
horizontal size
Go to full version
