Main > Monitor/Video Forum
Wells Gardner D9400 vertical is off. Looking for help
Pages: << < (3/4) > >>
vargas14617:
Thanks for quick reply. Will give it a try
vargas14617:
--- Quote from: grantspain on August 06, 2019, 01:41:27 am ---so that looks simple enough to me
trapezoid
pincushion
vertical shift
vertical size
horizontal size
Thanks worked. Just still have to figure out original problem
grantspain:
do the vertical size and vertical shift both work
vargas14617:
--- Quote from: grantspain on August 07, 2019, 02:37:13 am ---do the vertical size and vertical shift both work
yes the vertical size increases size but mostly the bottom of image just keeps going down. Shift moves imGe up or down and maxes at 100 but does not reach top.
grantspain:
its possible there may be an issue in the vertical deflection circuit
what happens if you adjust vertical linearity?
Go to full version
