Arcade Collecting > Merit/JVL Touchscreen
Fan speed
lilshawn:
yeh those fan tach signals can crap out and not show anymore. replacing the fan will fix it right up again. you may be able to go into the bios and ignore the tach for the CPU if you know it's spinning... but that's a crap shoot for when it DOES fail.
SCking:
Fans ordered. Fingers crossed. I looked high and low in bios to ignore fan alert but didn’t see any options.....
SCking:
New fans installed.... same old problem. Any other suggestions?? I’ve looked in bios to ignore fans, but I could not find anything
mahkeymike:
--- Quote from: SCking on July 29, 2019, 09:04:25 am ---New fans installed.... same old problem. Any other suggestions?? I’ve looked in bios to ignore fans, but I could not find anything
I don't think that would work anyway. The software monitors the rpm speed. If it drops below like 5000 it throws that cpu fan speed too low error. If your mobo's rpm sensor is fooked, you will need to most likely replace the mobo. Or modify the software to not check (if you know how)
SCking:
Yep. Def would have replace mobo. I’d have no idea how to remove that software. And I got the tech from JVL trying to tell me I have to order the specific fans from betson. $33 a pop...... smh
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
