Main > Monitor/Video Forum
Hantarex polo 25-28 multisync horizontal with control (SOLVED)
Pages: << < (8/9) > >>
perjmolsen:
Well... now I also have lost my red...only blue left  :dizzy:
I could wiggle the big resistor  to the red R526, then I could get the red back, so I reflowed it but no luck.
Pulled out the resistor and checked it, it still fine = 6K8
When I has the monitor on, the resistor to the red gets really hot...? what can cause it to get so hot?
I have also checked the BF859 on the red gun, thats fine
perjmolsen:
--- Quote from: princess prin prin on January 22, 2020, 05:32:55 am ---
--- Quote from: perjmolsen on January 21, 2020, 05:43:08 pm ---I have now put in a new LM1203 - still no green
But checking voltage will tell you if the signal is present or not so you know if you have to look ahead in the circuit or back.
OK, I will check the volt  :cheers:
perjmolsen:
LM1203
Green
Pin 6 in = 2.3V
Pin 25 out 3.6V
princess prin prin:
Green out is pin 20.
perjmolsen:
Hi  :cheers:
Fu*k   :censored: me sideways... and call me eddy!   :banghead:
I have now all my colors back!  :applaud:
1. The missing green removed all the solder on T504, and cleaned the area with alcohol, solder T504 back and - blue color!
2. The missing red.. well... between T502  and R503 there where NO connection, I could not see that it where a bad solder connection, but my multimeter showed OL
Ran a jumper, and RED where back! -> and now the big R527 resistor does not get so hot as before, so it where caused by no connection.
So back to my curved image... but I think that I might solve that one day also  :laugh2:
Go to full version
