Main > Monitor/Video Forum
Hantarex polo 25-28 multisync horizontal with control (SOLVED)
Pages: << < (7/9) > >>
perjmolsen:
--- Quote from: grantspain on January 21, 2020, 06:06:07 pm ---does the green cut off have any affect
When I turn the green cut off up, I can see a small change in the picture, but only a small change
perjmolsen:
Checked the components marked with green.. still no green  :hissy:
At the schematic, the green starts at "K501 7" is there any before that I need to check?  :notworthy:
grantspain:
have you checked r534
perjmolsen:
--- Quote from: grantspain on January 22, 2020, 03:28:01 am ---have you checked r534
Yep, it is good 1.000k
princess prin prin:
--- Quote from: perjmolsen on January 21, 2020, 05:43:08 pm ---I have now put in a new LM1203 - still no green
But checking voltage will tell you if the signal is present or not so you know if you have to look ahead in the circuit or back.
Go to full version
