Arcade Collecting > Restorations & repair
Power cord solution
<< < (2/2)
Mike A:
Yeah. The one I was looking at was like 25 bucks. It is not super cheap, but it provides a solution with less wires. I also like the idea of pulling out the cord when I move a machine.
PL1:
You can save quite a bit if you don't need the EMI filter.
https://www.mouser.com/Connectors/Power-Connectors/AC-Power-Entry-Modules/_/N-axiqi/
  Product: Inlets
  Filtered: Not filtered
  Current Rating: (select every option with "10 A")
  Fused: (as desired)
  Switch Function: (as desired)
Mike A:
Thanks. That helps. I don't really need the EMI filter. My games are all plugged into a power conditioner. I just figured they are in every cab. When I die the next owners will have to deal with it. Except for the Time Pilot cab. I want to be stuffed in it, set adrift, and burned up for my Viking funeral.
Gilrock:
Yep that is one spot where I deviated from original on my Robotron cab.  I have it running with this:
https://www.amazon.com/gp/product/B073RLXRPB/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Drnick:
--- Quote from: Mike A on May 16, 2019, 01:04:31 pm ---Thanks. That helps. I don't really need the EMI filter. My games are all plugged into a power conditioner. I just figured they are in every cab. When I die the next owners will have to deal with it. Except for the Time Pilot cab. I want to be stuffed in it, set adrift, and burned up for my Viking funeral.
Now that sounds like a good way to leave this mortal plain :applaud: :applaud: :applaud:
Navigation
Message Index
Previous page
Go to full version
