Author Topic: GroovyArcade live-CD 2022 (collaborative effort)  (Read 326629 times)
Substring
  • Last login:February 25, 2026, 02:07:44 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
Re: GroovyArcade live-CD 2022 (collaborative effort)
« Reply #560 on: July 19, 2024, 04:10:14 pm »
GroovyArcade 2024.07 released :)
Nothing really new about it besides a bunch of updates that would anyway come with a uual update in GA.
Just a few more troubleshooting tools for the ISO (like fixing UEFI after the GA entry has been lost)
mappy24
  • Last login:August 18, 2024, 04:44:13 pm
« Reply #561 on: August 18, 2024, 04:44:13 pm »
I hope you can help me with this, I have a system that runs GroovyArcade 2020 perfectly with zero issues.  I'm trying to install the latest release and I can see Attract Mode OK, but when I select any game e.g. World Rally, it's like the frequency is wrong or something?  My monitor is a Hantarex Polo 20" and I've selected this in the video settings (I've tried Generic 15khz too, no change).
Here's what I see in game:
https://imgur.com/a/rynzxCl
Maybe a MAME video setting?
Any help appreciated!
Substring
« Reply #562 on: August 28, 2024, 06:10:21 pm »
Looks like a wrong monitor was selected. Try doing it again in gasetup
donluca
  • Last login:February 26, 2026, 08:25:38 am
« Reply #563 on: September 21, 2024, 05:13:12 am »
I've recently read that with 6.12 the linux kernel will have the realtime patches mainlined.
I was wondering if GA uses the realtime patches and if anyone has done any measurements against the "normal" kernel in terms of audio, video and input latency.
Always been curious about this.
2.- Inflatable dolls
Substring
« Reply #564 on: September 22, 2024, 04:28:19 pm »
The RT patch exists for years already, and was simply just not merged in the kernel. Quite some work has been made to have that RT patch merged for good inside the kernel. But maybe 2 years ago, Calamity made some tests with that patch: nothing better, nothing worse.
intealls
  • Last login:January 16, 2026, 05:54:53 pm
« Reply #565 on: October 21, 2024, 04:55:19 pm »
I'm seeing benefit from the -rt patches when maximizing framedelay and minimizing audio latency as outlined in this post: https://forum.arcadecontrols.com/index.php/topic,160023.msg1770960.html#msg1770960 . The incoming/outgoing samples plot should be a continuous line without jumps, the -rt performs much better than the one without. This is still valid for me a couple of months down the line.
But you really have to measure it (and do that over a longer period of time, and examine video as well as audio). However, in practice I think the only way anyone would really notice would be the audio pitch shifts resulting from skipped frames. There might be drawbacks given all the hardware GA runs on, but for me whenever updating GA I build a new -rt kernel to go along with it and install that manually. But there is probably only a benefit if you really, really want to do something about those last couple of milliseconds of latency, and it could perform worse for some hardware.
I've also attached a new version of the rate filter (still only PortAudio) which should reduce audio pitch shifts with -syncaudio and high frame delay levels in case anyone wants to try it.
edomatic
  • Last login:October 24, 2024, 04:01:22 pm
« Reply #566 on: October 24, 2024, 01:15:46 am »
Hi Intealls,
Could you elaborate on your findings with framedelay and where you noticed improvements using the RT kernel for GA.
You say you are in a couple of months, where do you notice the gains using RT?
intealls
« Reply #567 on: October 24, 2024, 12:23:29 pm »
Hi Intealls,
Hi edomatic,
First of all, I'm pushing this system (an i5-46x0k@4.5 GHz) to its absolute limits. I've increased the frame_delay granularity to 100 instead of 10, so I get a 10x resolution increase in frame delay granularity.
I can observe two things:
* For whatever reason, it seems like audio update routine (callback) sometimes does not come at its required interval without -rt, it doesn't happen often, but it happens. So when the sound system should fetch samples, it doesn't. I'm not sure it's down to the particular hardware I'm using, but -rt seems to help here. I've attached the plots again (less cluttered) and this can be seen as a downward step in the plot.
* Frame delay will block until the last possible moment before emulating the frame and vblank, and as such the time after releasing frame delay is super sensitive if we don't want to miss vblank. -rt seems to perform better in this regard. Missed vblanks can be seen as upward steps.
BUT - I've spent a _lot_ of time tweaking this system, enabling the -rt patches might actually degrade performance for a given hardware configuration. But for my particular hardware and software configuration -rt helps.
edomatic
« Reply #568 on: October 24, 2024, 04:01:22 pm »
Interesting stuff intealls!
Have you by any chance checked in with Calamity on his view on this?, i believe i read a comment from substring saying calamity experimented with this about 2 years ago ? but a lot can change in that timeframe off course,(patches,updates,improvements..).it looks like you are on to something.
I would love to test this rt kernel out to see what the impact is on the games in terms of framedelay/audio latency performance.
I myself am on a i7 4790k with substring’s latest GA build running in pretty much vanilla.i have not experimented with rt kernels, is it hard is to set that up or modify /add that functionality to the existing build i have?
Substring
« Reply #569 on: October 26, 2024, 04:10:32 am »
In terms of input latency, Calamity said the RT patch brought nothing when he tested. But I shouldn't speak on his behalf ;)
intealls
« Reply #570 on: October 26, 2024, 05:33:44 am »
No this would seem reasonable, I don't think the -rt patch would improve that all that much. Also, it would be brutally hard to measure this without some custom equipment. The runs I did were 15 minutes long I think and you can see there are a handful of framedrops. Checking next-frame response with a high frame rate camera (this is what I do anyway) for such a long time would probably drive anyone insane.
Hi endomatic, unfortunately it's kind of a painful process.
I've attached PKGBUILDs for linux-rt and GM with the rate filter patch. Building the packages is probably best done on something faster than the 46x0k, linux-rt package needs makepkg --skipinteg, or you'll need to add the sha512sums to the PKGBUILD.
Also, if you try this make sure to disable automatic installation of linux-rt on GA, otherwise you might lose 15 kHz on pacman -Syu.
Then:
Install linux-rt kernel and GM package.
Modify kernel command line (idle=poll is probably the most important one here, clocksource can probably vary between systems):
mitigations=off idle=poll tsc=reliable clocksource=tsc
Stuff run on startup (most from arch wiki, the performance governor is critical if not set through kernel, unclear advantage from all the other stuff):
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
echo performance > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor
echo 2048 > /sys/class/rtc/rtc0/max_user_freq
echo 2048 > /proc/sys/dev/hpet/max-user-freq
echo 0 > /proc/sys/vm/compaction_proactiveness
echo 1 > /proc/sys/vm/watermark_boost_factor
echo 1048576 > /proc/sys/vm/min_free_kbytes
echo 500 > /proc/sys/vm/watermark_scale_factor
echo 10 > /proc/sys/vm/swappiness
echo 5 > /sys/kernel/mm/lru_gen/enabled
echo 0 > /proc/sys/vm/zone_reclaim_mode
echo 1 > /proc/sys/vm/page_lock_unfairness
echo 0 > /proc/sys/kernel/sched_child_runs_first
echo 1 > /proc/sys/kernel/sched_autogroup_enabled
echo 3000 > /proc/sys/kernel/sched_cfs_bandwidth_slice_us
echo 500000 > /sys/kernel/debug/sched/migration_cost_ns
/etc/sysctl.d/90-max_user_watches.conf:
fs.inotify.max_user_watches = 600000
Allow arcade user to run mame with nice -n -20 (important):
https://wiki.archlinux.org/title/Limits.conf
nano /etc/security/limits.conf
#@student        -       maxlogins       4
*                -       nice            -20
# End of file
Reboot and then run mame:
nice -n -20 mame [options]
To measure use PortAudio with a low latency (-pa_latency 0.004 or 0.008 or similar) and do nice -n -20 mame game -pa_log -v | grep 123456.123456 > game.log and use buf.py (in rate_filter.patch) to visualize it (requires python and some supporting packages, can't be done easily on GA machine).
Substring
« Reply #571 on: October 29, 2024, 11:40:48 am »
I'd be really open to anything that would bring extra perfs to GM, with or without the kernel patch.
Regarding port audio : too many people complained about it, so it's not default anymore. I find it way to complicated to set up, and it's pretty hardware dependant.
For nice and such : is it worh with a default kernel ?
intealls
« Reply #572 on: November 02, 2024, 12:54:43 pm »
Nice, Calamity has OK'd the idea of the rate patch - it should get rid of most audio pitch shifts but only works for PortAudio. But I've got some boring stuff left on it so it'll take some more time, it needs testing on Windows, and might need some additional cleanup etc. I'm currently running GA on an SBC so a vastly different machine than the i5, and it seems to perform the same on this platform, and seems to be needed here as well. But since most people use Windows it needs some testing there. Maybe it should be added as an "experimental improved soundsync" option or something.
For most cases I think it should be adequate to do -sound portaudio -pa_latency 0.0xx  -audio_latency 1 to get improved audio latency. It should then use the default audio device, but I'm not sure how that works in GA with ALSA etc, it's up to PortAudio itself. When manually selecting the sound device they can sometimes switch order (so if you have two, sometimes one shows up as hw:1,0 and other times as hw:0,0 which can be really irritating). But this could probably be fixed with udev, but also needs some tweaking.
But in the general case, PA will require more tweaking than SDL, it's the nature of the beast unfortunately.
I think some of the tweaks are probably beneficial, most of them deal with pushing framedelay. If you're looking to add something to GA I'd say probably the most helpful one would be to set the performance governor and run GM with -nosleep. Of all the tweaks this is probably the one that helps the most. Keep in mind though that power will go up (and heat as well). So it's probably not a good idea to use it on a laptop. Also nice is good if there are many background processes, -20 is probably overkill though.
But generally, most of the improvements will come when trimming the latencies. Most of them are from https://wiki.archlinux.org/title/Professional_audio and https://wiki.archlinux.org/title/Gaming#Improving_performance .
pixeltao
  • Last login:August 08, 2025, 04:43:10 pm
« Reply #573 on: January 14, 2025, 12:03:04 pm »
I hope I'm not breaking any forum rules already (this is my first post here). I registered just to say that I've built a GroovyArcade using an old ATI graphics card from the 2010s during the holdidays and it's freaking awesome! Playing all of these arcade games on my D-series CRT is just perfect! I already got 2 MiSTers but having the option to play the huge MAME library (including CPS3 and Midway games) is really cool. I was hoping to support this via a patreon or something, but I've read on github that it's not a thing for GroovyArcade, so I wanted to at least share how happy I am this exists. Fantastic work!
Cheers
Substring
« Reply #574 on: January 15, 2025, 03:51:57 pm »
GroovyArcade is Free. I'm not asking any kind of retribution for it. I'd feel really ashamed of getting money from assembling stuff mostly done by others. So no, it's just free, eriod.
And I'm glad it worked like a charm for you :)
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #575 on: January 26, 2025, 11:57:14 pm »
This is working really well now :)
« Last Edit: February 04, 2025, 06:17:31 am by Sledge »
camebackhaunted
  • Last login:January 03, 2026, 11:10:47 am
« Reply #576 on: February 13, 2025, 02:42:32 am »
Can anybody recommend a gun that works well with groovyarcade please?
Substring
« Reply #577 on: February 13, 2025, 03:47:50 am »
CRT guns work but ... The problem with CRT guns is that their calibration depends on the screen resolution. And considering we play arcade with as many resolutions as games, it's a pita
Can't tell about IR guns or any other technology
camebackhaunted
« Reply #578 on: February 13, 2025, 05:08:59 am »
Complicated with the multiple resolutions isn't it.  I guess IR would be the best solution perhaps?
imfirus
  • Last login:February 19, 2025, 11:04:47 pm
« Reply #579 on: February 19, 2025, 11:04:47 pm »
Hi, to all
I love groovy arcade, i use it with my intel I7 old PC and runs buttery smooth.
Since yesterday, i installed a fresh new Groovy Arcade 2022.1, thats the one my motherboard recognice perfectly.
All was installed good as always, but when i tried to install the retroarch frontend, i never could open it, it only opens the groovymame frontend.
Could you help me, did someone got this new error with retroarch??
When i tried to reinstall retroarch, it give me a message like this: "pacman -syu" and something about questions and my keyboard. This never happened before.
Please, help and thanks for your hardwork
Substring
« Reply #580 on: February 21, 2025, 05:09:27 am »
My guess is that your system couldn't update normally. Hard to tell just so. Using 202.01 iso is not a good idea either, updating will be a little complicated
antoniomauro
  • Last login:February 11, 2026, 09:12:57 am
« Reply #581 on: November 26, 2025, 10:34:09 am »
Hi!
I'm a little in trouble with my first ga hd installation.
After selecting 15khz and completed the entire installation process, after the reboot, the output is at 31khz
I've selected generic 15khz monitor type but nothing change...
Thanks in advance
a little update:
Boot process, ga setup and frontend ignore resolution an monitor settings (always at 31khz)
Games run at 15khz
Any help is appreciated
« Last Edit: November 27, 2025, 10:03:14 am by antoniomauro »
Substring
« Reply #582 on: December 18, 2025, 09:07:08 am »
what monitor and what GPU connector have you plugged to your CRT ? Selecting 15kHz is not enough, you have to go through the process of detecting your monitor and answer questions
antoniomauro
« Reply #583 on: December 19, 2025, 02:57:51 am »
Monitor is an intervideo 15khz fixed.
GPU in connected via a dvi connector.
I've done the detection process at installation time after read that the setup recognized an lcd as monitor type.
Substring
« Reply #584 on: December 19, 2025, 04:53:18 am »
Did you have a LCD plugged at the same time ? You may boot on it to see the boot menu, but then unplug it. You CRT MUST be connected otherwise the process can't set things up right. So the easiest method is:
- plug LCD, boot iso
- highlight the expected boot mode
- swap monitor and only have your CRT plugged
- press enter
- answer questions
antoniomauro
« Reply #585 on: December 19, 2025, 09:41:11 am »
Hi S,
lcd was unplugged immediatly after the 15khz choice ad boot.
The rest of setup was all shown on arcade monitor.
I'll try to repeat the process one more time on christmas holidays
Substring
« Reply #586 on: December 20, 2025, 03:24:32 am »
at worst, I'll give you the commands to fix this. I'll need to know the connector name (DVI-I-1 most probably) though
3dfan1
  • Last login:January 15, 2026, 09:48:01 am
« Reply #587 on: December 20, 2025, 06:55:51 am »
hello,
i have 2 questions:
1. is there a way to upgrade just mame version to the latest version posible manually in groovy arcade? i have tried to upgrade from the "system update" but when the update finishes and i reboot pc, i get "no such file or directory" here is a link to a picture of the mentioned error:
https://drive.google.com/file/d/1T20IHeI8J-shGnttOvj8M_tF2XpRa7Jm/view?usp=sharing
i have also tried with the option related to just upgrading groovyarcde specific items but also with no luck.
i have tried this multimple times, tried installing on another disk, SSD with enough free space but always the update ends with errors, the groovyarcade version a am tried to update from is 2024 08 version.
2. is there a way to set audio to mono output globally from any menu from the linux settings itself? since the arcade machine only have one speaker and some games dont have the option to mono output only
hope i can get help being advising on those questions,  i am not really experienced with linux by he way, thanks
sk8ersublime
  • Last login:December 24, 2025, 07:55:39 pm
« Reply #588 on: December 24, 2025, 07:35:25 pm »
Has anyone tried using a 3H dual arcade USB2Jamma adapter? I got it working but I can’t get player 2.
I tried using the command:
options usbhid quirks=0x16c0:0x75e1:0x040
In /etc/modprobe.d/usbhid.conf but it doesn’t seem to make a difference. I only see JS0 in the /dev/input.
sk8ersublime
« Reply #589 on: December 24, 2025, 07:56:28 pm »
Well idk what I did, I turned the pc back on and it’s working now…so I guess a full shutdown was needed. Reboot wouldn’t fix it
Deathblow81
  • Last login:Today at 05:21:56 am
« Reply #590 on: February 05, 2026, 11:48:59 am »
Hi All,
I've obviously hit a problem and need some advice...
I just done a fresh install after my previous went wrong for some reason after moving house.
After the initial installation to HDD, I can't get the monitor resolution right, it wont let me change in setting either, just says nope!
It was fine when running the 'Live-cd' (can't add games). After installing to HDD the resolution changes.
I'm running 31k Naomi Cab.
Any help much appreciated,
Substring
« Reply #591 on: February 16, 2026, 09:34:26 am »
I've blocked resolution change for 31kHz monitors. If you ever lose display, you're in trouble solving things on your own. What's the real question in fact ? You have no display ? Or you wanted to change the resolution ?
Deathblow81
« Reply #592 on: February 19, 2026, 01:54:35 pm »
Does that mean I can't run 31khz at all?
I have a display, its the wrong resolution, (Screen split/ blurry)
Yes!
Thanks for your time!
Substring
« Reply #593 on: February 23, 2026, 05:17:56 pm »
What's your resolution, apart from saying it's a naomi cab ? What resolution did you expect ?
Deathblow81
« Reply #594 on: Yesterday at 03:45:23 pm »
It's a UK Cab, nanoao 2030 I believe (standard monitor)
