Author Topic: Need help making FFWD behave as a toggle  (Read 2185 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: November 23, 2018, 11:54:59 pm »
I'm pretty sure there is no setting to make MAME's FFWD functionality work as a toggle instead of having to hold down the button, without recompiling the code.
Could somebody tell me what I would need to change in the code to make this happen?
Notice that I'm referring to FFWD not throttle, which does behave as a toggle.
Thanks in advance.
"The Manuel"
TheManuel
Re: Need help making FFWD behave as a toggle
« Reply #1 on: December 03, 2018, 08:56:29 am »
I ended up using AHK to implement the toggle functionality when pressing the FFWD key.  Luckily, no messing around with the code and custom builds were needed.
"The Manuel"
