Author Topic: Led ribbon installation with ultimate i-pac  (Read 2051 times)
strblast
  • Last login:November 21, 2018, 07:44:35 am
« on: November 20, 2018, 11:25:11 am »
Hello.
I would like to put a rgb ribbon in 12v and make it work with my ultimate i-pac controller. How could I do?
It's good :?
https://www.casimages.com/i/181121014232929119.jpg.html
Thank you by advance
« Last Edit: November 21, 2018, 07:44:35 am by strblast »
Maupoie74
  • Last login:September 13, 2020, 01:37:51 pm
Re: Led ribbon installation with ultimate i-pac
« Reply #1 on: September 13, 2020, 12:43:28 pm »
Altough this topic is 2 years old, I hope you figured this out..
I've got the same question
mahuti
« Reply #2 on: September 14, 2020, 12:48:59 pm »
Ultimate IO has a separate power supply. Why not just reduce the 12v to 5v and plug it into the Ultimate IO like normal.
You can get a voltage regulator  if you don't want to build anything yourself
