Main > Main Forum
Lunar Lander thrust lever questions
PL1:
Since you're mapping to a flightstick that is probably spring-loaded to return to center, you might want to map MAME's "P1 Pedal 1 Analog" (thrust) input to "Joy 1 Y Axis -" as DarthMarino demonstrates from 1:30 - 2:05 in this video.
"Joy 1 Y Axis"
- Stick centered = 50% thrust.
"Joy 1 Y Axis -"
- Stick centered = 0% thrust.
- Stick full forward = 100% thrust. ;D
As always when dealing with actual analog controls, set the "INC" and "DEC" inputs to "none".
TheManuel:
I'll check that out. Last night I mapped it to the stick Y axis by using the in-game menu but I could not get precise control of the thrust, i.e., it would not go to a consistent level of thrust when centered. I ended up mapping it to the slider which made thrust a lot more predictable. I'll watch the video tonight and see if I can get a better configuration.
Thanks.
negative1:
here's a possible new thruster control that GRS might make.
later
ne gative 1
