Author Topic: Wells monitor on NFL Blitz - only V Sync? (no H Sync?)  (Read 1296 times)
Midcoastsurf
  • Last login:November 02, 2020, 11:19:14 am
  • I want to build my own bartop
« on: July 20, 2018, 03:06:37 pm »
This monitor was never working right when I got this project.  I only see 5 wires coming into the connector (the purple one temporarily connected to pin 1 is coming off the V Sync on the JAMMA connector.
Should there be an H Sync wire plugged into this header pin?  I'm confused.  I also get mixed comments on which pin the sync wire should be on.  Some say pin 1 at the end, but the board shows V Sync next to the ground wire.
Someone wrote WG 25k7401 on the top of the chassis frame, so I assume that's what the monitor is.
  • Last login:April 09, 2024, 07:27:18 pm
Re: Wells monitor on NFL Blitz - only V Sync? (no H Sync?)
« Reply #1 on: July 20, 2018, 03:31:50 pm »
is the pcb in STD or MED res mode? Any other PCBs you can test with?
I had a blitz back in the day, it was wired the way yours is.
Midcoastsurf
« Reply #2 on: July 20, 2018, 04:01:44 pm »
I only have a GT '02 board (no hard drive)...but I guess the boot screen would come up, right?
I also just read that the two sync inputs should be both tied into the single V Sync wire coming off the JAMMA connector.  Which is interesting, because someone originally had two wires connected to the single white-yellow wire going into the JAMMA connector (but now only one pin on the end).  I'm gonna try copying this set up...
« Last Edit: July 20, 2018, 04:10:36 pm by Midcoastsurf »
big10p
  • Mmmm, arcade classics!
« Reply #3 on: July 23, 2018, 07:05:31 am »
Have you tried just adjusting the H sync pot? All my JAMMA cabs just have the H sync pin connected which provides composite sync. The V sync wire is not connected.
