Author Topic: How tight does your coin door lock?  (Read 1161 times)
SeanFu
  • Last login:May 22, 2004, 09:56:37 pm
  • I learn everything the hard way.
« on: February 04, 2004, 10:11:02 pm »
I just installed some barrel locks into my over-under coin door(s).  The doors have some "rattle" to them when they're locked.  I don't think a shorter lock would work.
Should I employ my hammer here? or is this expected.
APFelon
  • Last login:January 11, 2026, 06:54:36 pm
Re:How tight does your coin door lock?
« Reply #1 on: February 04, 2004, 11:21:30 pm »
Hammer or pliers should do the trick. You might want to remove the tab from the lock first (although I admit I usually don't).
APf
mahuti
« Reply #2 on: February 05, 2004, 12:51:21 am »
Pliers work fine. :)
paigeoliver
  • Awesome face!
« Reply #3 on: February 05, 2004, 12:55:19 am »
Your lock probably came with several different bars that can be installed on it to tune it to a better fit for your application, from there you bend it a bit to make it fit better.
You still may have some play in it though. I have lots of games, and the coin doors vary a bit in how tight they lock.
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« Reply #4 on: February 05, 2004, 01:50:48 pm »
A little bit of foam around the inside edge can make the rattle stop.  I bought mine from a local collector and he had a foam gasket already made for this very thing.
