Main > Project Announcements
javeryh's Small-ish Bartop ["Jack Attack!"]
Pages: << < (48/108) > >>
Mike A:
no magnets. velcro.
javeryh:
--- Quote from: Mike A on August 05, 2018, 05:34:31 pm ---no magnets. velcro.
The thickness of the velcro will throw things off, unfortunately.  That would be easy and I have a roll of the stuff already.
javeryh:
Next up was getting the monitor glass in place with the black bezel.  What a pain.  I'm not even sure this is going to work.  I think it will but not 100% yet.
What I decided to do was use some wooden clips just screwed in place behind the glass.  Easier said than done.  This required very precise drilling for the screws in order to avoid any gaps or for the glass to be loose.  I also used some double-sided tape in addition to the one screw for each clip for extra strength.  Not sure it matters but it can't hurt.
Here are the clips screwed into place.  The first picture is at the top of the cabinet.  The monitor glass slips up and under the batton that is used to secure the speaker panel and the wood clip holds it in place from behind.  This was the easy one.
On the bottom of the glass, there is no such batton or anything to use to hold the front of the glass in place.  I also had to worry about gravity because there was noting on the bottom for the glass and bezel to rest on.  I decided to use the same aluminum bracket I'm using as a marquee retainer to hold the marquee in place.  It is a 1/2" x 3/4" 'L' bracket sprayed black.  In order to get this to work, I had to cut a 1/16" slot in the wood clip for the 'L' bracket to slide into.  Not sure if you can see it in the picture.
The 'L' bracket is angled to sit flush to the top edge of the control panel.  It seems to be working, however, the 'L' bracket is actually just floating and not secure to the cabinet in any way.  I have not solved this issue yet and the only thing I can think of is to use some super glue inside the slot so that the 'L' bracket would be permanently attached to the wood clips (but not the cabinet body) so that the 'L" bracket would span the width of the cabinet being held in place by the wood clips (which are screwed to the sides of the cabinet as shown).  I think this is the solution but once I bust out the super glue there's no turning back!
Here is a shot of both clips in 1 pic so you can see how it all works (this is obviously done on both sides of the cabinet):
I did manage to stand up the cabinet and take a few pics.  The monitor glass and bezel aren't moving and they seem to be secure (and this is without the super glue):
Tonight I'm going to take care of the marquee light and continue thinking about how to fasten the control panel to the cabinet while still making it removable.   :cheers:
Mike A:
lookin good.
Jimbo:
That's looking lovely.  Is that tinted glass?  toughened/safety?  How thick?  How far from the monitor screen are you planning on mounting it?
I love the angle of the back, and that it's not dead vertical like mine.  Very sylish and streamlined looking.  :applaud:
Go to full version
