Author Topic: RESOLUTION ADJUSTEMENT Wells Gardner 7400  (Read 1518 times)
martin789
  • Last login:December 14, 2017, 03:13:42 pm
« on: December 13, 2017, 11:48:06 am »
I have a Wells Gardner 25" K7400 and I must adjust screen position and size H V in some game on MAME. Did try powerstrip but not so much
adjustement.
Is there a multisync module that will plug on K7400 and recognize vertical and horizontal frequency and keep screen adjustement for each resolution?
Excuse my poor English, I'm french Canadian :)
buttersoft
  • Last login:April 21, 2024, 08:06:32 am
  • Is running at 15kHz
Re: RESOLUTION ADJUSTEMENT Wells Gardner 7400
« Reply #1 on: December 13, 2017, 10:44:56 pm »
Horizontal size and position can all be done in the modelines. Powerstrip should be able to handle that, once the h-width is set a little wider physically.
For vertical size it can't really be done with timings. Besides which a lot of resolutions will be using similar fresh rates.
martin789
« Reply #2 on: December 14, 2017, 02:49:17 pm »
So how can I adjust Mortal Kombat(53 hz) verticaly vs other 60hz game?
buttersoft
« Reply #3 on: December 14, 2017, 05:47:55 pm »
With the vertical size pots, sadly.
Apart from that, you might try creating a single resolution that is larger than you need. Not sure what MK runs, but if it was 320x256 you'd create, say, 320x280, but turn off the scaling in MAME/GM. Would that work?
