Main > Main Forum
KADE miniArcade 2.0 beta release
PL1:
Do the "combo" inputs (Button Mapping IDs 18-23) send a single button press to the Xbox or do those inputs send more than one button press to the Xbox?
For example, the Button Mapping ID 19 (port B2) "Output As" is labeled "Back + White".
Does grounding that input send one button press "Back + White" or does it send two button presses, one "Back" (Button Mapping ID 8 ) and one "White" (Button Mapping ID 4)?
lilou:
--- Quote from: PL1 on February 08, 2020, 08:46:33 am ---Do the "combo" inputs (Button Mapping IDs 18-23) send a single button press to the Xbox or do those inputs send more than one button press to the Xbox?
I'm not sure to understand your request (I don't speak English perfectly), but if you use the option "output as back+start" for exemple, when you use only this button , the xbox will received information "back is press" AND " start is press
does that answer the question?
PL1:
--- Quote from: lilou on February 08, 2020, 02:17:09 pm ---
Yes. Thank you for confirming that grounding one "combo" input causes the board to output 2-4 button presses.
--- Quote from: PL1 on February 07, 2020, 08:51:34 pm ---
--- Quote from: lilou on February 07, 2020, 04:23:14 pm ---with only 12 buttons is too short. I need 3 more :lol
I don't know if the Xbox protocol will handle more functions/buttons than the ones Bruno marked in the "Output As" column of the Mapper program. :dunno
- The only functions not assigned a port by default are Right Trigger, Left Trigger, the analog stick inputs, and some multi-button combos.
Did you find a way to add the three more buttons?
If you did, which functions/Button Mapping ID numbers did you use for them?
lilou:
--- Quote from: PL1 on February 08, 2020, 03:20:02 pm ---Did you find a way to add the three more buttons?
i was searching how to use B1/B2/B3/D0/D1 ports who was not available on the "mapper" due to "Rj45" functions
So i found this option, and now i can use it like other one :) :
--- Quote from: lilou on February 08, 2020, 06:51:46 am ---
So now, i have almost alls ports available on my arduino pro micro :)
(i just have to test "shift" function, I haven't tested yet)
PL1:
I'm not asking how to enable the RJ-45 ports. :banghead:
I'm asking which Button Mapping ID numbers you used for the three more buttons you said you needed.
Here are the Button Mapping ID numbers and the assigned functions for Xbox:
- 0-5, 8, and 9 are the usual Xbox buttons. (8 buttons)
- 13-16 are the D-pad, which acts like 4 buttons. (4 buttons)
- 32 and 33 are left/right trigger. (2 buttons?)
- 10 and 11 are left/right thumbstick button press? (2 buttons?)
- 24-31 are used for analog thumbstick inputs. (probably not usable as buttons)
- 6, 7, 12, and 34-46 have no function assigned. (probably not usable as buttons)
- 17-23 are "combos" of other buttons. (no new buttons here)
Seems like the place to find your three more buttons is 10, 11, 32, and/or 33, right?
