Main > Main Forum
KADE miniArcade 2.0 beta release
Pages: << < (21/31) > >>
lilou:
i solved my problem  :laugh2: it's realy stupid !
I was used a copy-paste of the code from the PDF tutorial
--- Code: ---avrdude -p atmega32u4 -P COM12 -c avr109 -U flash:w:MINIARCADE2.hex -U
eeprom:w:EEPROM.eep -C avrdude.conf
--- End code ---
but the real code is :
--- Code: ---avrdude -p atmega32u4 -P COM12 -c avr109 -U flash:w:MINIARCADE2.hex -U eeprom:w:EEPROM.eep -C avrdude.conf
--- End code ---
one "ENTER" between and it dos not work correctly ! So, in only one line (not 2) the code works perfectly !
my eeprom is now upload !
 :cheers: :cheers: :cheers:
PL1:
Glad you got it working.   ;D
lilou:
--- Quote from: PL1 on February 07, 2020, 03:50:48 pm ---:applaud:
Yes thank you, i am happy !
Do you know if is it possible to not use the RJ45 option, and add more button on the bord ? like the original "kade miniarcade" (and not miniconsole) ?
because with only 12 buttons is too short. I need 3 more  :lol
PL1:
--- Quote from: lilou on February 07, 2020, 04:23:14 pm ---Do you know if is it possible to not use the RJ45 option, and add more button on the bord ? like the original "kade miniarcade" (and not miniconsole) ?
I don't know if the Xbox protocol will handle more functions/buttons than the ones Bruno marked in the "Output As" column of the Mapper program.   :dunno
- The only functions not assigned a port by default are Right Trigger, Left Trigger, the analog stick inputs, and some multi-button combos.
Yes, you can re-map the RJ-45 ports if you do not plan to use them to connect to a GameCube, Nintendo64, Wii, WiiU, or NES Classic console (User Guide, page 7) or to another console through a Multi-Out board. (User Guide, page 6)
Looks like these ports are available:
B1, B2, B3, D0, D1, D4, and F7
lilou:
you are the best !
I'm excited ! it's very super cool !
Go to full version
