Main > Main Forum
Replace X-Arcade Tankstick Trackball with U-Trak?
Pages: << < (2/3) > >>
GeoMan:
So i got a Happ 3" to replace the trackball in the Tankstick. I had to widen the hole by 2mm with a dremel for the Happ to fit, but everything went smooth! There's simply no comparison between the original X-Arcade trackball and the Happ...
Here's the finished Tanlstick mod everything except the box is replaced with much better components.
suds64:
Can you help me with your happ 3 trackball replacement on the tank stick.  Do i need all of the following for this project:
Suzo Happ 3" White High Lip Trackball Assembly
Suzo Happ 3" Trackball Mounting Kit
Suzo-Happ to Ultimarc U-Trak Trackball Adapter
Easily connect a Suzo-Happ or other standard arcade trackball to Ultimarc's I-PAC2 or U-Trak USB adapter.
Does the Happ 3 still work on the Tank Stick - even though i see this note with that trackball - Note: This does not support USB, it has a standard AMOA harness for arcade games.
PL1:
I assume you have an X-Arcade PS2/USB trackball like this one, right?
--- Quote from: suds64 on May 24, 2022, 12:22:10 pm ---i see this note with that trackball - Note: This does not support USB, it has a standard AMOA harness for arcade games.
You want a Happ trackball with red boards and a molex connector.  There are adapter cables and optical (mouse) encoders like the Opti-Wiz3, Opti-Pac, IPac2, etc. that will convert the quadrature waveforms from the red boards into USB mouse movements.  Related post here.
Avoid the Happ trackballs with green boards and Happ's built-in USB encoder.
--- Quote from: PL1 on July 26, 2021, 11:35:26 am ---
--- Quote from: giantsean on July 26, 2021, 10:12:24 am ---What is the advantage of the red v. green?  Better resolution, more reliable?
The red board (P/N A052-1011-00) is an updated version of the green board. (P/N A052-1010-00)
- The red board has faster response time so it doesn't have problems with backspin which can be a big problem for games like Golden Tee.
If you replace the trackball, get one with red boards and a Molex connector. (white connector, lower right)
Avoid the version with a built-in USB & PS/2 encoder kit (P/N 56-0113-00K) that has the main PCB (P/N 55-0301-00) with the encoder and a satellite optical PCB. (55-0302-00)
- Not obsolete, but not recommended.  Some people have complained about backspin problems.
suds64:
Scott Thank you for your help!
This is what I'm going to order and it looks like what you recommened:
(2 Items)
Suzo Happ 3" White High Lip Trackball AssemblySuzo Happ high lip arcade trackball with 3" White ball.
3" White High Lip Trackball assembly.
Original Suzo Happ part number 56-0100-11HL
Highly specialized components provide the ultimate performance trackball for use with Golden Tee Fore and PGA Tour machines.
Tested and preferred by elite "Gold Division" Golden Tee Fore players.
Case is constructed of durable impact resistant polycarbonate plastic material that resists cracking from impact.
"Red Board" PCB has improved circuitry to guarantee an optimized performance signal both at low and high rpm speeds.
Optic board utilizes surface mount technology and superior optics for increased reliability.
Standard AMOA harness included.
Use on updated control panel design for Golden Tee Fore 2003 - 2005 games.
Easy replacement on many trackball games, such as: GLOBAL VR's PGA Tour Golf and Golden Tee Fore, Live, Power Putt, Unplugged, Silver Strike Bowling & Live, by Incredible Technologies
And
Trackball Cable for Opti-Wiz "No-Solder"
It looks like the Suzo Happ 3" Trackball Mounting Kit is not required?
suds64:
Will  this work just as EASILY?
Suzo-Happ to Ultimarc U-Trak Trackball AdapterWith this adapter you can easily connect a Suzo-Happ or other standard arcade trackball to Ultimarc's I-PAC2 or U-Trak USB adapter.
One side has 3-pin and 4-pin Dupont pin connectors for plugging into the I-PAC2 or the U-Trak USB kit and the other end has a 6-pin Molex connector to plug the trackball into.
Note: Reference the photos on this page for connecting to your I-PAC2 or U-Trak USB kit once you receive the adapter, printed instructions are not included in the package.
instead of
Go to full version
