Main > Main Forum
Replace X-Arcade Tankstick Trackball with U-Trak?
PL1:
--- Quote from: suds64 on May 25, 2022, 10:50:36 am ---This is what I'm going to order and it looks like what you recommened:
(2 Items)
Suzo Happ 3" White High Lip Trackball AssemblySuzo Happ high lip arcade trackball with 3" White ball.
3" White High Lip Trackball assembly.
Original Suzo Happ part number 56-0100-11HL
Trackball Cable for Opti-Wiz "No-Solder"
Those two look good, but you'll also need an Opti-Wiz 3 encoder (w. 72" Micro-USB cable option?) to go with that "no-solder" cable.
--- Quote from: suds64 on May 25, 2022, 10:50:36 am ---It looks like the Suzo Happ 3" Trackball Mounting Kit is not required?
That appears to be the case.
GeoMan posted this external pic of his mod where you can see the trackball carriage bolt heads and the original Tankstick overlay -- no additional mounting plate.
One other thing that hasn't been mentioned in this thread is that it would be a good idea to connect the Happ trackball's ring terminal with two green ground wires to the Opti-Wiz USB connector shield ground -- AFAIK that's the closest thing to Frame Ground on the Tankstick.
- These wires bleed off the static electricity generated by the acrylic trackball rolling on the steel rollers.
- You can connect them using a ring terminal and 0.020" safety wire wrapped 540 degrees around the outside of the Opti-Wiz Micro-USB housing like the attached image. ;D
retrometro:
--- Quote from: PL1 on May 24, 2022, 02:29:30 pm ---I assume you have an X-Arcade PS2/USB trackball like this one, right?
--- Quote from: suds64 on May 24, 2022, 12:22:10 pm ---i see this note with that trackball - Note: This does not support USB, it has a standard AMOA harness for arcade games.
You want a Happ trackball with red boards and a molex connector. There are adapter cables and optical (mouse) encoders like the Opti-Wiz3, Opti-Pac, IPac2, etc. that will convert the quadrature waveforms from the red boards into USB mouse movements. Related post here.
Avoid the Happ trackballs with green boards and Happ's built-in USB encoder.
--- Quote from: PL1 on July 26, 2021, 11:35:26 am ---
--- Quote from: giantsean on July 26, 2021, 10:12:24 am ---What is the advantage of the red v. green? Better resolution, more reliable?
The red board (P/N A052-1011-00) is an updated version of the green board. (P/N A052-1010-00)
- The red board has faster response time so it doesn't have problems with backspin which can be a big problem for games like Golden Tee.
If you replace the trackball, get one with red boards and a Molex connector. (white connector, lower right)
Avoid the version with a built-in USB & PS/2 encoder kit (P/N 56-0113-00K) that has the main PCB (P/N 55-0301-00) with the encoder and a satellite optical PCB. (55-0302-00)
- Not obsolete, but not recommended. Some people have complained about backspin problems.
After removing the 4x bolts, how do you remove the X-Arcade trackball unit? the instructions on x-arcade's site are there but the photo links are down.
