Main > Raspberry Pi & Dev Board
Modifying Pi .img
<< < (4/6) > >>
Titchgamer:
--- Quote from: BadMouth on January 17, 2017, 08:35:31 pm ---
--- Quote from: Titchgamer on January 17, 2017, 07:46:49 pm ---Not sure about the resolution but retro pie works pretty good for that.
I have retropie installed.  I dislike it very much.
It seems to be for people who want to use an Xbox360 controller and HDTV.
How do I bypass or hide the retropie menus?
(This would be going in a 6" cabinet with a 2.5" screen.  The retropie menus aren't going to be readable.)
You can hide the config menu  using kiosk mode.
If you want to hide the actual retropie menu itself you can do it as described here:
https://www.reddit.com/r/RetroPie/comments/33gz62/retropie_30_hide_retropie_option_menu/
But instead of editing the CFG, I duplicated it, Changed it and then dropped it into the /opt/retropie/configs/all/emulationstation folder.
That overides the standard one but allows you to easily revert back if needed by changeing the name so it goes back to the standard CFG
pbj:
12 hours later, still cranking,
 :angry:
HaRuMaN:
Couldn't you just have got a slightly larger card?  :dizzy:
pbj:
Yeah, those cards are $40 each, and you have no idea if it'll work until you open the package.  So... no.
pbj:
Still cranking.....
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
