Main > Raspberry Pi & Dev Board
Modifying Pi .img
<< < (3/6) > >>
Titchgamer:
Not sure about the resolution but retro pie works pretty good for that.
BadMouth:
--- Quote from: Titchgamer on January 17, 2017, 07:46:49 pm ---Not sure about the resolution but retro pie works pretty good for that.
I have retropie installed.  I dislike it very much.
It seems to be for people who want to use an Xbox360 controller and HDTV.
How do I bypass or hide the retropie menus?
(This would be going in a 6" cabinet with a 2.5" screen.  The retropie menus aren't going to be readable.)
pbj:
Alright, this is currently cranking, so let's see if it works.
The .img file was copied to an external hard drive to a folder called images.  We'll pretend it was called bigimage.img
I also downloaded and copied pishrink.sh from this link to the same folder:
https://github.com/Drewsif/PiShrink
The hard drive was plugged into a Pi running emulation station.
I exited out to the command prompt...
cd /media/usb0
cd /images
fdisk -l bigimage.img
I looked at the Start field for bigimage.img2 and multiplied that number by 512.  Let's pretend the result was 1234567
Then I said:
mount -v -o offset=1234567 -t ext4 bigimage.img /mnt/img/two
Then cd /mng/img/two
Then I poked around and deleted a few ---steaming pile of meadow muffin--- N64 games.
Back out of that to the images folder....
Then:
chmod +x pishrink.sh
sudo bash pishrink.sh bigimage.img smallimage.img
And now we wait.
nitrogen_widget:
--- Quote from: BadMouth on January 17, 2017, 08:35:31 pm ---
There are a few images over on the attract mode forum that might work for you.
mahuti:
--- Quote ---I have retropie installed.  I dislike it very much.
I use retropie in arcade cabinets. Front end is using Attractmode rather than the default emulation station.
--- Quote ---How do I bypass or hide the retropie menus?
You've asked a number of questions in this post that are off-topic to resizing the partition. Maybe make a new post and I can work on answering in detail.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
