Author Topic: So ... 3d Printers....  (Read 240694 times)
  • Last login:May 01, 2024, 01:02:33 pm
    • GroovyGameGear.com
Re: So ... 3d Printers....
« Reply #1360 on: December 24, 2023, 12:08:04 pm »
Nice parts!
I decided long ago that I would no longer consider a bed slinger machine to be viable without automated mesh leveling and a dual Z-axis.  Additionally, my Ender3 V2's all got upgraded filament feeders mounted directly above the hot-end assembly and that crazy Bowden tube was cut down to a couple of inches of filament guide tube.  This makes it a quasi-direct extruder.  Since doing this, prints have been much more uniform and reliable and I have only had to replace a nozzle once due to a severe clog, and that was probably due to overcooking the filament during prolonged pre-heat cycles (don't do that :) )  I've literally yet to have a failed print otherwise.  The modifications increase the cost of the printer pretty substantially, but IMHO, they are worth every penny.  Also, touch screens are over-rated for displays that small. They just limit the amount of information one can display or make it difficult to operate :)
Corners can be weird on a lot of automation processes.  Especially when higher speeds come into the equation.  With CNC cutters, it usually manifests as burning of the material, or rounding of the corner to account for the abrupt change in direction at speed.  It's all physics.  The heavier the head and the faster the change in direction, the more tricky this can be to overcome, as the travel must slow down.  As you found, it seems that in the case of 3D printing, the effect of the ramp down to the corners results in heavier extrusions/drool at those features.  Ramp speeds/acceleration/deceleration settings can be altered to give an acceptable result, but sometimes the design of the part is better altered a bit to avoid the problematic features if possible.
It's definitely nice that you got the filament change command to work.  But another way to do that for those parts would be to just have a black program and a green program.  It would require generating the g-code for the complete part and from that, creating separate files for each color through some manual editing, but it would negate the need for any babysitting of the machine.  Maybe something for others who want to do this type of thing to keep in mind if that capability isn't already present (or working properly) on their machines.
« Last Edit: December 24, 2023, 12:19:35 pm by RandyT »
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #1361 on: January 10, 2024, 10:36:50 am »
Over the holidays I upgraded my Ender 3 - Dual Z drive, direct drive, new allmetal hotend, printed a fan shroud. I bought an Ender 3 V3 SE, and purchased an HP 705 G4 to run multiple instances of Octoprint and cameras.
  • Last login:Yesterday at 10:34:50 pm
« Reply #1362 on: January 10, 2024, 12:46:50 pm »
Can it print pirate figurines?
05SRT4
  • Last login:Yesterday at 10:26:09 am
  • Check out my Pow Pow
« Reply #1363 on: January 10, 2024, 05:16:32 pm »
I need to dust off the ole resin printer, whatch ya need?
  • Last login:Yesterday at 06:44:33 pm
« Reply #1364 on: February 04, 2024, 06:18:53 pm »
all you bambu owners with an A1
« Last Edit: February 04, 2024, 06:20:26 pm by lilshawn »
« Reply #1365 on: February 05, 2024, 06:44:12 pm »
Screwed right in.
This part is unobtainium, other collectors I know are happy to see this come to fruition.  Found out one of my mosfets is blown on my $300 repro MPU.  But that’s another thread.
Well, well, well...
https://www.siegecraft.us/presta/index.php?id_product=79&controller=product&id_lang=1
  • Last login:Yesterday at 09:03:50 pm
« Reply #1366 on: February 17, 2024, 03:32:03 pm »
Never thought I'd post in this thread. Stuff happens, things change. So I have a side hustle to my part time job  (I am an Access Technology Specialist) working in a electronics hobbyist shop generally one day a week. There we sell a large range of things, you name it, everything from Raspberry Pi stuff, Arduino, security cameras, retro gamer hardware and .. 3D printers.  To sell these things I at least had to learn something about them. We have variety of demo units including the Ender 3 V3 SE as well more expensive models, both filament and resin. Point is, I'm printing stuff off in the shop on the Ender 3 which just happen to be for my Vpin  ;D.  I know quite a few folk use Fusion 360 for their design work but I prefer 3ds MAX just because I've been using it for so long.  Apparently the Creality Ender-3 V3 KE  is the sexy-go-to machine right now, I'll have a play with it and see...
« Reply #1367 on: February 18, 2024, 07:48:10 pm »
Even on superfine mode filament printers are still coarse to my eye. But this print will be refined quite a bit for a project.
Fursphere
  • Last login:Yesterday at 10:13:19 pm
« Reply #1368 on: February 20, 2024, 08:32:45 am »
Use a smaller nozzle, like a 0.25mm.   However, this makes print times increase dramatically on larger parts.  You can get down to 0.07mm layer heights, which is almost resin-like quality.
  • Last login:April 30, 2024, 08:57:01 am
« Reply #1369 on: February 20, 2024, 08:11:24 pm »
https://ellis3dp.com/Print-Tuning-Guide/articles/index_tuning.html
3D printing is an endless progression of "could be better" and diminishing returns.
...and there are limits to how good an fdm print can look.
« Reply #1370 on: February 21, 2024, 02:43:04 am »
Thanks, yeah that print was done with a standard 0.4mm nozzle which is what our shop demos run. We have resin printers on display but work health safety rules mean they don't actually get to print anything.
Ha hah, well filament printers have their uses I guess. By the time I'm finished with that print you wont think it came from one.
« Reply #1371 on: February 21, 2024, 10:13:55 am »
honestly, i don't really care what it looks like, as long as the part the comes out of the printer is functional.
i mean, yeah i print out decorative items once in a while, but for the most part i'm printing replacement parts for something broke, or a part to achieve a function. if it does that function, it's good enough for me.
my first layers could be better, my attention to preventing warping could be better, my corners could be square-er, my elephant's foot is very slight, but i trim the edges anyway... i occasionally get under extrusion on my outer layers...but also really, why waste the time and effort and filament testing out 2000 different fixes for stuff when it's "good enough" for what i need.
as long as my 3d print can hold up the rod, or hold the circuit board, or skim the scum, or drain the water... good 'nuf!
picrel... new output board adapter endplate for an amplifier. one that no one will ever see but me when i plug the stuff into it and then basically never again until it breaks... if it's ugly...who cares... if it's half ass structurally sound and it's holding the board...  :cheers:
« Last Edit: February 21, 2024, 10:15:45 am by lilshawn »
« Reply #1372 on: February 21, 2024, 12:51:41 pm »
It is possible to make pretty parts with FDM, but it involves printing with the loathsome ABS and finishing with chemical vapor.  I experimented with this a bit.  It's a fair amount of work and really only good for one-off "artistic" works, and that which does not involve fine details.  IMHO, resin printers are a better choice for pretty things, so long as they need not be too tough.
But for relatively strong and functional parts, it's hard to beat FDM.  I would venture a guess that today there are millions of little 3D-printed pieces of plastic in the world, doing jobs that otherwise would have been impossible for the amount they cost to produce.
« Reply #1373 on: February 21, 2024, 02:46:35 pm »
Like I said, FDM printers have their uses.. We get some customers coming in that print simple functional parts for things and the only thing they care about is "how fast can the new model print". Those same customers are only printing in the toughest plastics as well.  A few of the guys in the shop have their own resin printers so I get them to print me the occasional "pretty" things when needed.
I just wanted to be able to understand the end-to-end process of design to print stages in 3D printing, at least enough to speak convincingly to customers anyway.  Finishing techniques for printed things like Randy mentioned interest me. Not just to smooth prints but paint them as well. Anyone got any examples of painted stuff that looks slick? For example, I see really nice resin printed figures but I never see any painted or detailed?
nitrogen_widget
  • Last login:March 30, 2024, 09:10:09 am
« Reply #1374 on: February 21, 2024, 08:49:04 pm »
had a watermain break in the basement last month.
Happy New Year.
printers survived but i had to fit a basements worth of crap into 3/4ths of the basement to make room for contractors.
all fixed.
cost more than i could of ever imagined.
so no printing for a while until i throw stuff out and make a real shop.
not going back to an old bench with a yoga mat on it and a cheap table top green house as an enclosure.
going to build more shelves and throw more stuff out so it looks less like a storage locker with a path and more like a shop.
lol.
« Reply #1375 on: March 18, 2024, 11:38:43 pm »
I've not had a good week.  It doesn't really matter why.  *sigh* Anyway, I'm thinking of buying me my very own 3D printer!  I watched a Creality K1 working at speed in the shop the other day, very impressive!  A bit pricey though, so I think I'll get me a V3 KE.  They seem to be the best value for money. Has anyone got one?  Are they good? Alternatives?
« Reply #1376 on: March 20, 2024, 11:21:23 am »
I don't own one, but the V3 KE seems decent considering the price.  The important bed-slinger upgrades, like auto-bed-leveling, direct extruder and dual-z-axis drive are already there.  Those alone represent over $100 in add-ons for one of their lower tier offerings.  There are other niceties, like Klipper out-of-the-box and the slide rails as well, although the value of those things depends on your usage profile.  Klipper can improve the appearance of parts printed at high speeds, but if appearance is important, slower speeds almost always yield a better result, especially where materials other than PLA are concerned.  And the value of the rails is also a bit controversial.  They add weight, but also rigidity to the beam and are less likely to wear out over long and hard use.  That stated, the regular wheels are very accurate, durable (when not overtigthened) and are dirt cheap and easy to replace if ever necessary.
Normally, I would shy away from units with special nozzles.  However, since this is a Creality machine, I suspect that they will be supported for a reasonable time to come, and it helps that there are several models which use the same nozzle design.  Just be aware that they are a consumable and that they cost more than the typical nozzles, so you'll likely be tempted to try to fix one (often times unsuccessfully) rather than tossing it and using a new one.  Just factor in the cost of the replacements and have plenty on the shelf so you won't need to in a pinch.
But the consensus seems to be that they are decent machines, and Creality has a reasonably good track record compared to other brands. So for the price, and more importantly what you get for it, I think it's something I would buy as a first 3D printer as someone who has already been exposed to them and intends to use it productively.
« Last Edit: March 20, 2024, 11:27:47 am by RandyT »
« Reply #1377 on: April 23, 2024, 08:06:20 pm »
Thanks for the info Randy, I ended buying the Creality V3 KE. My discount to myself was generous  :lol
Reprinted a few parts for my project with some improvements.  I'm happy with the results:
« Reply #1378 on: April 24, 2024, 04:57:54 pm »
Spiffy!  So, on the webs, did you tweak some things to deposit like that or were there more manual artistic shenanigans used?
« Reply #1379 on: April 24, 2024, 06:26:58 pm »
Thanks, that web print is as per the mesh that I designed:
Basically started with circles and line type objects and injected several noise modifiers to get the look.
Something interesting is extracting game meshes, smoothing them into high-res models, then outputting to STL for printing. A complex mesh would best be divided up into several parts to reduce supporting structures and printing complexity. Here's an example I extracted just for fun (legalities aside  :) - Armor frame from Fallout 4:
« Reply #1380 on: April 25, 2024, 11:51:50 am »
i build wiff squars and sirkuls an stuff in tinkercad.
real cad is 2 hard
« Reply #1381 on: April 25, 2024, 12:45:00 pm »
I considered that they might be fully modeled, but my brain recoiled at the possibility. It does look nicely organic!
real cad is 2 hard
I was fortunate enough to be exposed to parametric modeling at my last 9 to 5 (over 20 years ago...oof) and it was a slog.  When it was being explained to me and while watching someone use it, I could literally feel my synapses re-routing and it was painful.  But one day, as if by some sort of biological sorcery, it just "clicked" and it was downhill from there.  Those learning curves can sometimes feel like a straight vertical line, but they are surmountable.  The tools have also become quite a bit better since then.
That stated, you might want to take a look at Plasticity.  It's CAD, but meant for those who might feel more at home using something like Blender or those who like modifying primitives (squars and sirkuls an stuff..lol.)  There's still a learning curve that my brain rejects due to the parametric modeling programming I received, but it looks very capable in the hands of someone more accustomed to more artistic ways of designing things.
But on the free side for local installs, there are basically only a couple of decent options: FreeCAD (and it's forks) and Blender.  FreeCAD has it's own ways of doing things, which parametric modelers who are already trained seem to despise, but if you are going in cold, there's no reason not to learn it.  Blender, as you probably know, is an insanely capable beast and there is a plugin in the works for doing CAD functions within it.  With all that capability, the learning curve is particularly steep. It's a 3D modeling application, so there is a ton of stuff not particularly aimed at functional design work.  So unless your interest is in the artistic over the functional or you already have experience in that realm, I wouldn't recommend that direction to someone who just wants to design their own parts.
« Reply #1382 on: April 25, 2024, 05:29:49 pm »
I was tempted to make them even more bumpy and irregular but settled for the result you see. 3D printers are such a natural progression from 3D design. I guess it's taken me this long to acquire one because I wasn't that impressed with them in the early days. I have a few build tasks coming up which will need printed parts. I'll post the results here as well.  I'm also doing a larger articulated mech spider with more detail, just for fun! Happy to share the STL when its ready.  :cheers:
